Old 07-16-2007, 12:03 AM   #1
Maxwell007
Electrical Problems
I took apart my dash board on my 72 C30 and disconnected several circuits looking for a short circuit. I found it and fixed it. Now that I have put my wiring back together, my headlights no longer work.
The hot wire to the headlight switch is hot and when I turn on the switch, I can detect current in the blue and tan wires going to the fuse panel. But, when I try to detect current on the other side of the fuse panel (the engine compartment side), I get no readings. My service manual says that headlights are fused with a circuit breaker located at the headlight switch but I can't find one at the switch or anywhere else for that matter. All of the fuses in the panel are okay....I checked each one.
Any ideas?
Thanks,
Chuck
Maxwell007 is offline   Reply With Quote
Old 07-16-2007, 04:52 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Electrical Problems
kick the dimmer switch, then click it from hi to low and back.
Of course, this is after makin sure the switch is still plugged in.
