Got it out of the garage>>>
![]() YYYYYYYEEEEEEEEEEHHHHHHAAAAAAAAAAAAAAA!! It Drives!!!!!!!!! Took it to the store and bought a celibration BEER ![]() ![]() ![]() ![]() The brakes are still a bit squishy and I have to remember the R&Ps are brand new and need to sorta not get on the BBC buttttt... YYYYYYYYYYYYYEEEEEEEEEEHHHHHHHHHHAAAAAAAAAAAAAAAAAAAAA!!!! It Drives !!! YA! ![]() Draglink ties into the tierod instead of the steering arm. The steering is soo smooth, one finger steering and I don't even have my ram installed yet. Some have made comments about the draglink not being level with the tierod but so far I don't see that as an issue because of the way the drag link goes to the tierod instead of to the steering arm like everyone else with crossover/highsteer... I leave on Thursday for Hollister so I'll have some better action shots and stuff ![]() ![]()
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks ![]() |
Re: Got it out of the garage>>>
congrats!!! now you just need to take it out and put it to the test!!
SKINNY TIRES RULE!
Right on. See if it will light up all 4!
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
Post Whore
![]() Join Date: Feb 2000
Looks great Burt! Can't wait to see the action pics. New tires, new front axle - can't get much better than that!!!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
#5 | |
14FF w/disk brakes, new 4.56R&P & bearings w/new 1410 yoke ![]() ![]() I still have a lot of clean up to do but hey they are in and rollin down the road so all the rest is just to makum PREETY ![]()
Very NICE!
The only issue I see with that draglink is the fact that a straight tube would be stronger and less likely to bend. I am assuming you acquired that one from somewhere so for now it had to do? How much lift is that?
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
I talked with WFO and we may switch it to a straight one like you said. More for looks than function, the tube used is perrty damn thick I don't see it bending to easily. The orginal design had to be changed and that draglink was originally going to be connected to a steering arm not the tierod like it is now. Another reason I love WFO's service, he will do whatever it takes to make it right
![]() My front is 4" Rancho springs that are over 14yrs old and the rear is 5.5" Superlift about 10yrs old, oh and I have a 3" bodylift.
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
Burt, that thing came out awesome. Nice work and enjoy the beerz. Shame your not on the right coast, Rausch Creek was a blast this weekend, would have enjoyed wheelin' with you....
Are you posting up more howto's, so I can learn? Waiting on the action shots. J.
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
I'm not sure I know HOW I did it hahahah
Actually the front was easier than the back, the front being all bolt on affair in place of my D44. Were the rear I had to grind off the spring perches and shock mounts. Then re-weld the perches(about 1.5" inword) and made shock mounts. Drivelines being the biggest issue so far, My rear fits but it is streached out about 1.5" more than before, wereas the front had to be cut down by 2"... Other than that my only other issue is getting all the damn air outof my brakelines and I'm not to sure about the used calipers but I have no money for parts so they will have to do for now, this winter it is new rotors, pads & calipers for all 4 corners. Other than that it wasn't too hard..well the money and time envolved was peerrty tuff but hey I Got-R-Done ![]() ![]()
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks ![]() Last edited by Burt4x4; 07-17-2007 at 11:03 AM. |
Dude, you outo try those speed bleaders, about 7 bucks a pop, but they work great. No more wifey " I don't think it was all the way to the floor" routine. Or my leg is getting tired.
Nice build Burt, let's hear how it works in the dirt.... J.
Hey Burt,
If you go straight with the drag link....um what you doing with that one? I am in the process of making a cross over setup on my Dana 44. I got everything. But I gotta bend up the drag link. I am using a 86 and up center drag link like yours so mine will attach in the same spot but under the leaf, so it needs a bend. |
#13 | |
I have heard of thoes sped bleeders, nice to know they worked for you...the pump method is definatly not working out for me too well, plus it is taking forever and my for arms are getting a workout squeezing the piss outa that damn thing ![]() Progbly should just get my son in there to foot pump the brakes for me....
#14 | |
#15 |
I was talking to my buddy over at PacFab and he suggested I gravity bleed the brakes. basicaly start at pass side rear, crack open the bleeder, master cyln cap off and let it leak out until 1/2 the fluid is gone, tighten then fill then move to the other side...so on and so forth..hell it worked!
![]() ![]() Next stop = Hollister Hills for some Mayden Voyage fun!! YYYYYYYYEEEEEEEHHHHHHHHHHHHAAAAAAAAAAAAAAAAAAAAAAAAA ![]() ![]()
#16 |
Post Whore
That's good news - would hate for you to have a brake issue while out having a good time. So, you gonna flop it over on the driver's side this year
#17 |
Hey! What are you trying to jinks me or you just want me to finnish painting it olivedrab:
![]() The plan is allways rubberside DOWN!!!!!! ![]()
#18 |
Post Whore
Hmmm, I like that - I take it you got rid of the beer induced camo paint?
#19 |
hahahah Ya the beer camo turned into a complete MESS when I was out there drinking yet again and decided to make it 'better'....NOT! Then next day I was like..oh man that is terrable so I covered it all up...there is such a thing as too much camo..looked like hell
![]() Someday I may get it painted, nothing fancy just back to one color...or not.. ![]()
#20 |
Post Whore
Note to self, when drinking with Burt, keep vehicle out of range of spray can.
#21 |
Hey Burt, thanks for the tip on gravity feed bleed, never heard that one...
Separate locations...beer...burt...camo paints ![]()
#22 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Green camo makes anything look good.
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
