Active Member
Fuel gauge...
I know this has been posted before however I'm just getting around to asking about it now. My Fuel gauge, full or empty tank, always shows right around half way on the gauge. I have checked the +12v and the negative and all checks out ok. I remember a resistor??? solution that was posted in the past? Anyone have a bead on where I can get one of these, or how else to fix this issue?
Thank you
"The Great State of Florida" |
Active Member
Re: Fuel gauge...
Bump???
Re: Fuel gauge...
mine only reads the last half tank or so! you can drive like 60 miles before it gets down to the full mark!
can't stand that needle bounce when you are getting low!! |
Re: Fuel gauge...
check out this article it might shed a little light on the problem.
http://www.6066gmcguy.org/Electrical-02.htm Good luck, Jerry |
Dave's not here, man
Re: Fuel gauge...
Have you tried testing the sending unit with an ohmmeter? I'd check that first.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
