Old 07-16-2007, 08:00 PM   #1
jkade
jkade's Avatar
Here is a question for you....
I was looking at my blazer when I was taking it to the storage building and the rear end looks like it needs to go back a inch or 2 to center it in the wheel well. Have any of you done this to correct the problem? I also know the front suspension needs to go foward at least a 1 1/2" or 2". Why do most folks not fix this when they build a truck?
jkade is offline   Reply With Quote
Old 07-16-2007, 10:29 PM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Here is a question for you....
I did. The rear is easy, just put it where you want it, re-drill, and bolt in. The front would be a little harder though without R&P. Dropmember corrects this.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 07-16-2007, 11:38 PM   #3
SCOTI
SCOTI's Avatar
That pic looks like the c.member was slid toward the front of the truck based on seeing the trans output shaft, the location of the new c.member hardware vs. the old frame holes, & the front of the t-arms in their mount.
Am I not seeing this correctly?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
