Old 07-16-2007, 08:27 PM   #1
BIGPIMP
PIMPING RIDES
BIGPIMP's Avatar
Rear Brakes
guys i swapped the rear axles on my 65 c/10 for 5 lug axles now the problem is when i buy new brake hardware they don't seem to fit . i have bought new shoes ,drums ,cylinders ,but the spring and stuff look a lot different . i was told that up to 72 parts would fit . help please
1964 CHEVY 1/2 C/10 FLEET
1981 CHEVY 1/2 C/10 FLEET
1995 DODGE 1500 V6 FLEET
EAST
http://www.flickr.com/photos/bigasspimp/?saved=1
BIGPIMP is offline   Reply With Quote
Old 07-17-2007, 12:24 AM   #2
Captainfab
60-66 Nut
Re: Rear Brakes
The 5 lugs for pickups started in '71 and should be basically the same until around '75 or '76 when GM went to a 2 1/2" wide shoe. Where did you get your axles from? I've not done what you have with the axles, but it would seem the hardware from the above mentioned years should fit. One thing that just popped into my head is that starting in '66, the brakes had self adjusters on them. In '65 they did not. Could this be the difference you are refering to?
Old 07-17-2007, 09:23 AM   #3
Chevy Fleetside
Chevy Fleetside's Avatar
Re: Rear Brakes
You put axles in but you still have the 1965 backing plates. The only thing you changed was the fact that is was a 6 lug but is now a 5 lug the rest in the same except for the drums of course. This is why I op for changing out the whole rearend..
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 07-17-2007, 09:26 AM   #4
jkaylor68gmc
jkaylor68gmc's Avatar
Re: Rear Brakes
You shouldn't have to change anything but the drums. I bought the CPP or Ece kit, can't quite remember but the kit just came with axles and drums. all my brake stuff worked. I didn't have to change any of the brrake hardware, mine still uses the '65 stuff.
1947 International KB-1
1957 Chevy Bel-Air riding low
1962 swb fleetside
2002 Chevrolet Silverado 7-inch lift on 35 Daily driver
2016 Chevy Tahoe Better halves ride
jkaylor68gmc is offline   Reply With Quote
Old 07-21-2007, 08:54 PM   #5
BIGPIMP
PIMPING RIDES
BIGPIMP's Avatar
Re: Rear Brakes
bought the axles from cpp also ,they fit perfect ,got the rearend back together .didn't know i had to change the backing plates ,i for some reason can't get the springs to fit ,the brake shoes and drums look the same .
EAST
Old 07-23-2007, 01:09 PM   #6
rickf
rickf's Avatar
Re: Rear Brakes
Did they skip 65 with the self-adjusters?
My 64 C10 has self adjusters on all 4.
rickf is offline   Reply With Quote
