Old 07-16-2007, 09:42 PM   #1
77GMCSerria
Question 2wd to 4wd kits?
Does anyone make kits to convert a 1970 GMC 1 Ton dually 2wd to 4wd?
77GMCSerria is offline   Reply With Quote
Old 07-16-2007, 10:25 PM   #2
Mudder
Mudder's Avatar
Re: 2wd to 4wd kits?
Never heard of one. You would have to get all the parts you are gonna need then do it yourself or have someone that knows what they are doing do it for ya. If you search here a little there are threads about changing front ends to 4wheel drive.
Mudder is offline   Reply With Quote
Old 07-17-2007, 07:35 AM   #3
There are "kits" in junkyards.A donor truck is the way to go.There`s alot more to it than front axles/driveshaft/transfercase.
Old 07-17-2007, 10:31 AM   #4
77GMCSerria
Does anyone have measurements or specifications for the different mounts and other stuff that needs to be fabricated to put the 4x4 components in a 2wd truck?
I don't know what I will be running for the t-case since I don't know if I want to keep the stock trans(SM465) or upgrade to the NV4500.
Old 07-17-2007, 02:53 PM   #5
FormerMember
I am currently doing this... with a 72 C30 frame.
I decided to go with 52" rear springs in the front using brackets from DIY4x
FormerMember is offline   Reply With Quote
Old 07-17-2007, 03:24 PM   #6
tallhoedude
ROCKWELL 5 TON CLUB !!
tallhoedude's Avatar
Not Trying To Hijack The Thread...but
Grendel,how Do You Like That Kit From Diy?ive Been Looking At It.
1970 K5 "ON THE ROCKS" PROJECT:500hp 6.0 fuel injected. 2wd sm465 trans,t136 2.5 ton transfercase,5ton rockwells with 9.34 gears,custom wheel disc brakes,full hydro steering20+" OF LIFT AND 67/35/25's..67" tall TRACTOR TIRES.."THE MUD SLUT!!"
MY BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=221935
1997 TAHOE,SAS D60 14B,5:13 DISC BRAKES,CROSSOVER STEER,HYDRO ASSIST,42 IROKS
HINT:NEW NAME "K5ontheROCKS!"
tallhoedude is offline   Reply With Quote
Old 07-17-2007, 03:26 PM   #7
FormerMember
Well, I am using it in two places, so I must really love it.
I am using it to convert a C30 to a K30 and also on a 71 K5.
