09-21-2002, 06:52 PM | #1 |
Resident Young Old Dude !
? Jackson Gear Drive???
I just picked up a PETE JACKSON cam gear drive, It's new in the box. The ladies husband died and sold his GOODIES. She came across this in the back of the garage and brought it in to me. She wanted $50.00 for it. There is no directions, And the way it looks the marks don't line up in the conventional way. There is also a BALL BEARING cam bushing,and timing bushings. A good buy, but I have to figure which side the BIG idler gear goes on. I love the whine.
DOES anyone use one of these?? RON |
09-21-2002, 09:25 PM | #2 |
I will dig my directions out tomorrow and let you know.
69-C10 LWB 71- fleetside shortbed It's a shame stupidity isn't painful Never play leapfrog with a unicorn |
09-21-2002, 11:50 PM | #3 |
Suburbans RULE!
I just looked at some Polaroids of my engine when I built it......the larger gear goes toward the passenger side of the block.
--Ben 71 GMC Suburban 4X4 The "Beast" 388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's. |
09-22-2002, 12:20 AM | #4 |
Thanks guys,
That helps... RON |
09-22-2002, 01:42 AM | #5 |
RON -- I DON'T HAVE A SCANNER, BUT IF YOU HAVE A FAX MACHINE (I DON'T) I'LL GO TO A COPY SHOP, & FAX YOU A COPY OF THE INST. THAT CAME WITH MINE. EITHER THAT OR I'LL MAKE A COPY & SNAIL MAIL IT TO YA. EMAIL ME JOHN AT FK9U812@AOL.COM (THE WINE IS COOL AS HE!!)
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
09-22-2002, 01:49 AM | #6 |
i did one a few weeks ago and have a scanner if you need the directions, email me at bogr97@aol.com if you need any help.
09-23-2002, 07:30 AM | #7 |
What are some of the disadvantages of the gear drive, the guy at the edelbrock booth at the Route 66 event said that in some cases with the engine in the truck there is no way to set the button gap and that they can cause other failure from shock and take up some 30 or more hp to run. I like the idea of having one but don't want to make problems for myself. Ed ke6bnl
Ed ke6bnl Agua Dulce 70 S.E. Los Angeles 70 Chevy short bed 1948 F3 ford pu 1949 F1 stock V8 flathead 3 on floor 1950 F1 pu street rod 1948 F6 Ford Dually/350sbc no bed stock trans&rear 1972 El Camino 4" chop 1953 Chevy 3100 2b daily driver 1970 SB 4X4 400ci 6in lift |
