Old 07-16-2007, 11:45 PM   #1
THOR 50
Over worked under paid
THOR 50's Avatar
Fan vs Fan shroud
I've had my truck for 10 years. (283 motor) Never had a fan shroud.
I plan on installing a/c in the near future so I purchased a used original non a/c fan shroud for my truck. Removed the fan, attached the shroud exactly where it should attach. Went to re-attach the fan and it does not line up. The radiator and shroud favor the drivers side by 1/2 an inch and sits about 1/2 an inch high.
Any suggestions to get a proper fit?
Roger
'69 C-10 with GMC front clip billet grill, 283CI, 400TH and 12bolt posiw/3.73 gears
THOR 50 is offline   Reply With Quote
Old 07-16-2007, 11:55 PM   #2
dirtball
dirtball's Avatar
Re: Fan vs Fan shroud
Are your motor mounts in good shape?
dirtball is offline   Reply With Quote
Old 07-17-2007, 12:44 AM   #3
redhead69
fugedaboutit
redhead69's Avatar
try loosening the upper supports, you can get some movement both ways. Had the same problem after swapping to a hd cooling system, got it close by the above and then had to hog the shroud holes out a hair to get it just right. Just a couple ideas
Currently truckless
redhead69 is offline   Reply With Quote
Old 07-17-2007, 12:58 AM   #4
THOR 50
THOR 50's Avatar
dirtball I'll have to check them.
redhead69 thanks I tried that was off way too much.
Roger
