Old 07-17-2007, 12:08 PM   #1
BigSky71
LAIDOUT
BigSky71's Avatar
Brake pedal staying part way down?
I have re-assembled my truck [71 2wd stock disk brakes] and have a nagging problem with the brake system. Everything is new except the brake pedal assembly and the prop valve. When I press on the brakes the pedal stays down part way, say 3". This keeps the brakes slightly applied, enough that the truck can't be rolled around the garage without lifting on the pedal each time. Does anyone know why my pedal would not want to return to the full and upright position? I have bleed the brakes, and the reservoir is full fwiw... thanks!
67 2wd Shorty
Build Pictures
BigSky71 is offline   Reply With Quote
Old 07-17-2007, 12:25 PM   #2
OlChev67
Ever heard of Beech Island??
OlChev67's Avatar
Re: Brake pedal staying part way down?
do you have a pedal return spring, if so it might just be worn out a little. it connects to the pedal and somewhere else under the dash.
OlChev67 is offline   Reply With Quote
Old 07-17-2007, 01:43 PM   #3
dave2953
Dave's not here, man
dave2953's Avatar
Try loosening the through bolt for the pedal rod. It only needs to be on tight enough to get the cotter pin installed. I've run mine down too far a couple of times and it makes the pedal bind on its pivot point and stick down towards the floor.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 07-17-2007, 04:09 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I've seen a bad booster do this too. My longhorn was like that when i first got it.
Old 07-18-2007, 10:54 AM   #5
BigSky71
LAIDOUT
BigSky71's Avatar
Yes! Thank you Dave for that suggestion, I had tightened the pivot bolt way too tight and it was holding the pedal, now all is good. My truck To Do List is getting shorter!
67 2wd Shorty
Build Pictures
Old 07-18-2007, 11:10 AM   #6
dave2953
dave2953's Avatar
Glad it was something simple
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
