Old 07-17-2007, 12:14 PM   #1
BlueDSM
70' Blazer on 80' Blazer frame?
The vehicle is:
1970 K5 Blazer 4x4
6cyl Manual
Drum Brakes in front
I'm was considering going the 2WD route, and slamming it on 20's or 22's....
I found a 1980 2WD K5 Blazer for cheap, it already has disc brakes and a 350/Auto.
Will the 70 body bolt up to the 80 frame? It would definitely make life easier....
Any help is appreciated
BlueDSM is offline   Reply With Quote
Old 07-17-2007, 12:51 PM   #2
1969k10stepside
Re: 70' Blazer on 80' Blazer frame?
The frames are longer on the newer k5s and arent shaped the same.
1969k10stepside is offline   Reply With Quote
Old 07-17-2007, 12:57 PM   #3
NTR72GMC
2wd FTW!!!!
NTR72GMC's Avatar
I think they have a shorter wheel base and you will most likely have to move around body mounts. But that 2wd would be good for the suspenion and drive train. I think that would be the better way to do it
NTR72GMC is offline   Reply With Quote
Old 07-17-2007, 04:13 PM   #4
72 CustomCamper
huh ???
72 CustomCamper's Avatar
69-72 Blazers have a 104 inch wheelbase. 73-91? Blazers have a 106.5 inch wheelbase...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 07-17-2007, 05:17 PM   #5
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Rob everything you can, use the 70 frame and covert it to a 2wd
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
