Old 07-17-2007, 03:02 PM   #1
shifty
Questionable
shifty's Avatar
been asked a thousand times
and i can't seem to find one guess i am not using the right words, but i swear it's been asked.
can you use a '68 crossmember with '72 arms, coils, spindles, discs, etc? or will it not work? both are from half ton.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 07-17-2007, 03:14 PM   #2
Chevy_Man
Tightwad
Chevy_Man's Avatar
Re: been asked a thousand times
I don't see why not shifty...........I would think that you can......
Eric
56 Chevy custom cab step side under construction
55 Chevy 210
68 SWB Stepside back burner under construction
72 Chevy LWB
84 CJ 7
05 Chevy 1500 Crew Cab
30X40 DOGHOUSE(shop) with many add ons
Chevy_Man is offline   Reply With Quote
Old 07-17-2007, 03:20 PM   #3
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Shifty, yeah it'll work fine. You will have to fab or find brake lines and use ball joints for the year of the spindles. You will also need the entire tie-rod from the newer truck (ends are different thread and the studs are bigger.) And you have to trim the steering stop on the new spindle (leave about 1/2 inch of it.) I swapped 72 disc spindles into my 69:
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 07-17-2007, 05:05 PM   #4
SCOTI
SCOTI's Avatar
68 & 72 a-arms are the same; it's the BJ's that are different. Disc spindles use a different BJ than drum spindles.
Use the required tie rods for whatever spindles you use.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-17-2007, 06:05 PM   #5
mvfd70
mvfd70's Avatar
Yes. That is exactly what i'm doing to mine. Changing ball joints and tie rod ends. Very easy swap
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
