Texas Big Wig
Help !!! Wheel lug Q????s
Ok heres tha deal
I have a 67 that the PO converted to 5-lug, but when he did he made it 5 x 4 3/4 instead of 5x5 ![]() So I want to change that, the rear is no big deal cuz I'll either swap rear ends or axles But the front is where my questions come in I found some sweet look'n 6-lug wheels today at a good price, so now I'm think'n bout go'n back to 6-lug But I still want disc brakes, what do I need to do this ![]() Please steer me in the direction I need to go, thanks Matt |
Texas Big Wig
Re: Help !!! Wheel lug Q????s
I'M TRUCK CRAZY!
Good question.... 5 x 4 3/4 is a car bolt pattern as far as I now. I would think the spindles would be different and wouldn't except the new rotors That's just my thought
I'M TRUCK CRAZY!
Well, HMMMMMMM do car spindls fit on these truck? I don't know
Texas Big Wig
I dunno either, I just consider it a mutt
I'm gonna pull the A-arms off a parts 73-87 I have, so I'll know what everthin is |
I'M TRUCK CRAZY!
You can buy 6 lug rotors that will bolt onto the splindle.
http://www.classicperform.com/Store/...ruck/CP4R5.htm |
![]() Join Date: Nov 2004
ECE sells the rotors as well. $$$ but very good quality.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 07-20-2007 at 10:53 AM. |
Is the back still 6 lug?
Texas Big Wig
No, I'm swap'n it out to a 6-lug I have lay'n around
Ok, why not 3/4 ton rotors ??? And if those won't work, would you use ECE or CPP Last edited by Spray-Bomb; 07-20-2007 at 05:16 PM. |
#13 |
This could be similar to what's on your truck to get the 5x4 3/4 pattern.
http://www.classicperform.com/Store/...k/6062CBK5.htm 3/4 ton spindle kit is $619 for stock heigth. http://www.classicperform.com/Store/...ck/6370SSK.htm |
#14 |
I think as far as the rotors go it's personal preference.
#15 |
Texas Big Wig
The reason I wanna find out if some stock 6-lug rotors will fit , is so I can save a few bucks
If there aren't any that fit, it's ok cuz I'll just buy the $130 rotors from CPP |
#16 |
Hellasick
![]() Join Date: Jul 2006
to do off the shelf 6 lug rotors, you will have to do this:
http://67-72chevytrucks.com/vboard/s...ad.php?t=35042 using 88-92 LIGHT DUTY 3/4 ton. otherwise, you will have to use ECE or CPP 6 lug rotors. I used an '85, with CPP rotors, no probs for me. woulda done the 3/4 ton one, if I knew about it at the time, just cause it is all -off the shelf-parts. as for the initial part of the post, you can buy kits that use full-size car brake parts adapted to our trucks with brackets and wheel bearing adaptors, sounds like what the PO did.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes) This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do. RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!! BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys |
#17 |
Old Skool Club
![]() Join Date: Jun 2001
My guess is that having a car bolt pattern says your spindles are sized wrong for truck-pattern rotors. That will make having the calipers in the right position a difficult guess. Truck rotors should be 12-inches in diameter. Car rotors may only be 10 or 11 inches. If that is the case, you can see why the caliper won't let the rotor be usable. Measure your current rotor to be sure that the rotor you buy will work on your spindles. You also need to know the O.D. of the spindle....hope you succeed in your task.
People take short cuts to save money, only to cause someone else to have to spend a bunch to fix it.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
#18 |
Texas Big Wig
70C10Toejam
The thread you directed me toward was a very good thread, but was for 88 up & thats not what I wanna do ChevLoRay As I said before, I'm gonna swap everything out to 73-87 front end parts (as that is what my parts truck is) So that I know what everything is |
#19 |
Texas Big Wig
I will be pulling a rotor off my parts truck, so I can take it down to my local parts store and see if a 73-87 or 88-98 6-lug rotor will intercahnge
I'll keep ya posted |
#20 |
im currently swapping mine to 5 lug 5x5 , looking for wheels i almost wish i was going 5x4.5 just for the wheel selection, im picky about wheels and havnt found any 5x5 that i like for under $2000, can find all kind of 4.5's though.
