Old 07-17-2007, 07:40 PM   #1
texas69truck
truck wont start
heres the story, its a 69 chevy with a 350/th350, running a 650cfm holly. so i ran out of gas and then the truck wouldnt run without being on the gas. Towed it home and checked to see if the carb was getting gas, it was but it wouldnt idle. so i figured the float was stuck...long story short i have replaced plugs, wires, and fixed the float on the carb. now it wont even start, when i crank it i hear a horrible noise and it feels like it seizes up. the fan still spins so i know its not locked up but what could the noise be comming from? It almost sounds like its comming from the bottom half of the engine. i dont know to much about engines but to me it sounds like something is stopping the crank shaft from spinning. hopefully i am wrong.
sorry for the long post and bad description but hopefully someone can shed some light for me.
Thanks in advance,
Travis
texas69truck is offline   Reply With Quote
Old 07-17-2007, 07:48 PM   #2
cdowns
cdowns's Avatar
Re: truck wont start
have you checked your oil level recently??
Old 07-17-2007, 08:37 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
while that sounds stupid, you may have flooded the hell outta it and it would be down in the oil, creating a very high level on the stick.
Old 07-17-2007, 08:44 PM   #4
MyakkaJeff
Junior Member
Sounds like it's seizing while trying to start? Are you sure you ran out of gas? Maybe a slipped timing chain or the timing is way out.
'63 C10 lwb flatbed
'66 C10 lwb stepside
'68 C10 lwb stepside (parts)
'68 C10 lwb fleetside (17 yr old son's ongoing project)
'03 HUMMER H2 (wife's)
'06 3500 flatbed liftgate (My work truck)
MyakkaJeff is offline   Reply With Quote
Old 07-17-2007, 10:53 PM   #5
jhow66
jhow66's Avatar
Take your plugs back out and crank it. Your carb is probably still flooding the cylinders with raw gas.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 07-18-2007, 02:04 AM   #6
texas69truck
Thanks for the replies. i check my oil on a regular basis and never let it get low. I will try cranking it with the spark plugs out tommorow and see what happens. Thanks again for the advice. i cant count how many times this board has helped me out with the ol' girl.
Travis
Old 07-18-2007, 08:58 AM   #7
grayw0lf
Travis
I think LonghornMan was suggesting you check your oil to see if it diluted with gasoline.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 07-18-2007, 12:44 PM   #8
68speedalert
Semi-Senior Member
68speedalert's Avatar
before pulling the plugs, disconnect the coil wire and see if it helps. If it does, check you firing order. If you've got them really screwed up, it's firing out of time and making it crank hard.
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre
'83 Jeep CJ-7, <80,000 miles, original owner
'04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer
'95 GMC K1500 Extended cab
68speedalert is offline   Reply With Quote
