Old 07-17-2007, 09:49 PM   #1
68gmsee
Active Member
68gmsee's Avatar
Thumbs up Warranty label question...
Howdy, y'all. Here's my project for when I retire. I've had it for about 15 years and used to drive it occasionally. Now that I'm retiring, I'm going to make it a driver again.
I'm getting some good info from this site again. Fantastic bunch!
Here's my question. There's a label in the warranty book that has this on it below the vin number. Anyone know what these numbers mean?
RXSTD 3.54 1D112657
TRSM318 GMC8
68gmsee is offline   Reply With Quote
Old 07-17-2007, 09:54 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Warranty label quetion...
is the label a metal tag?
Sounds like the protecto plate.
These numbers are a code that show certian things about your truck. The original owner's name and personal info should be on there too.
When ever it went in for warranty work, they'd slide that thing like the old school credit card slder things, and it would go into the paper trail of work done to that truck.
Old 07-17-2007, 10:07 PM   #3
dave2953
Dave's not here, man
dave2953's Avatar
Yep, those things are pretty neat. I still have a work order for my truck when it had a carrier bearing replaced under warranty. You can see where they copied the protect-o-plate info in the corner of the work order.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 07-17-2007, 11:00 PM   #4
68gmsee
Active Member
68gmsee's Avatar
Re: Warranty label question...
Yeah, Longhorn. It's a metal plate on the back of the warranty book my buddy gave me when I bought the truck. Has the name of his father and address etc..
I wonder if the RXSTD 3.54 has anything to do with the rear end ration?
Could the TRSM318 have something to do with the transmission?
btw: here's a pic of my 69 that I've had for about 20 yrs. That will be next on my list of "to do's."
Old 07-17-2007, 11:09 PM   #5
Longhorn Man
was your truck originally a big block truck? I *think* that's the only way to have gotten that gear...and even then, I don't think it was in 1/2 tons. I think the 1500 trucks got a 3.07 with a big block.
If you do a search on protecto plate... you may find the info. This one cat had a link... he pops in every great once in a while.
Old 07-17-2007, 11:10 PM   #6
72armyswbtruck
72armyswbtruck's Avatar
I No See Pictures
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 07-18-2007, 08:49 AM   #7
68gmsee
Active Member
68gmsee's Avatar
Longhorn. Re: big block ?...
The truck is original with 250 six, 3 on the column. I added power steering, power brakes and changed the trans for another with synchronized first gear for convenience. That's the only thing different on it.
I will get under the rear end and check for numbers.
Re: 72army not seeing pics.
Can anyone see them??? Since I'm not familiar with the photo stuff they may not have come out...
Old 07-18-2007, 11:09 AM   #8
dave2953
dave2953's Avatar
I can see them.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
Old 07-18-2007, 04:48 PM   #9
Longhorn Man
unless optioned otherwise, or swapped out at some point, it'll be a 3.73 gear
