Old 07-17-2007, 10:09 PM   #1
BAGGERSOCAL
Active Member
17" centerline fit on a stock C10 questions
Just picked up some 17" centerline rims for my 68 5 lug C10.
will they fit without rubbing the inner front fenders..
also what type of lugs /length do i use .
The rims have the covers for the lugs.
do i use the tapered acorn lugs or the tapered acorn opened end type?
Steve
BAGGERSOCAL is offline   Reply With Quote
Old 07-17-2007, 10:12 PM   #2
BAGGERSOCAL
Active Member
Re: 17" centerline fit on a stock C10 questions
rims
Old 07-17-2007, 10:58 PM   #3
BarryB
BarryB's Avatar
you can use regular plain jane acorn lug nuts with those since they have the cover over the lugs. as for the fit, need to know more about the wheel dimensions. back space and such. what did they come off of?? need to know also the tire size. has your truck been dropped or is it stock????
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 07-17-2007, 11:16 PM   #4
BAGGERSOCAL
Active Member
they came off a 70 swb
the holes have a taper to them.
so would i use the taper style acorn?
