Old 07-17-2007, 11:13 PM   #1
dan42
dan42's Avatar
power steering -
Is there any difference between a non power steering column, and a power steering column? In other words, can you put on a power steering unit onto a non power steering truck without changing the column or making large modifications?
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 07-18-2007, 08:25 AM   #2
Luvlegs
Luvlegs's Avatar
Re: power steering -
I'm getting ready to swap to ps and so far, I THINK the rag joint has to be changed as they are different. That's all I have found out so far.
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 07-18-2007, 09:39 AM   #3
OlChev67
Ever heard of Beech Island??
OlChev67's Avatar
I am still using the manual steering column, still same huge steering wheel too because I like it. dont remember if I used the old rag joint or just kept the one with the power steering box that I got, what would the difference be in the rag joints?
OlChev67 is offline   Reply With Quote
Old 07-18-2007, 11:26 AM   #4
shifty
Questionable
shifty's Avatar
i replaced the rag joint anyway, cause mine was wore out.
column itself is the same. depending on the year of the truck the intermediate shaft differs a bit between columns (at least the 70's models look diff't than mine), but this won't affect your install. i did a short writeup on how to swap (no pics, just info) and Krue put it over in the FAQ thread.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 07-18-2007, 12:55 PM   #5
dmsteele92831
A new rag joint isn't needed if yours is in good shape. If it's in not so good shape replace it. Mine was fine so it was re-used.
1968 c10 Chevy
2005 Infiniti G35
2006 Subaru WRX STi
dmsteele92831 is offline   Reply With Quote
Old 07-18-2007, 03:06 PM   #6
dan42
dan42's Avatar
thanks -
Philippians 4: 6-7
