Dropped truck pics
Does anyone have pics of a truck with a 2-1/2 & 4 drop? Thinking about doing mine but would like to see the stance in real life. Looking at dropped spindles on the front and springs for the back. No air bags here. Need to see how low this actually sits for these Saskatchewan roads! Thanks!
1967 GMC 1/2 Ton - A Work in Progress ![]() |
![]() Join Date: Feb 2004
Re: Dropped truck pics
Your a Brave Brave man...
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
Please Explain. Is dropping a terrible idea? Any input is appreciated...this is my 1st build!
Here's a lwb with a 2-4 drop
![]() And a 2.5-5 drop ![]() Hopefully I got the drop heights correct...2-4 should have no problems, even for our crappy roads. Hope its Ok with everyone to use these pics..I am sure they are both board members rides.
"You can take the man out of PA, but you can't take PA out of the man" |
You`ll be alright with a 2.5/4 drop.That`s medium range (a good comprimise) and you`ll have stock front springs.Just use 4" rearsprings,they are designed to ride that height.
Old Skool Club
![]() Join Date: Jun 2001
www.earlyclassic.com has a website that shows the truck with stock height, 2.5/4-inch drop and a 3.5/6-inch drop, all done on the same truck so you can see the difference.
I have the Early Classic parts on my truck and I love it. Rides good. Handle good. Handles the loads, too. My truck has coil springs, and it may make for a better finished product than a leaf sprung truck. My '96 has leaves and it doesn't ride nearly as comfortably.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
#7 | |
67 is sold
Here is my truck with a 3/5 drop, I don't have any clearance problems with it.
Grand PooBaa Member
Mine is close to what you asked for, 3" up front on stock spindles 4" in back.
#10 | |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Hey D, Is that black Cheyenne a Saskatchewan truck?
#12 | |
#13 |
WHYBYNU when old will do
Here is mine with 3.5/ 5.5 hope this helps
john
71 Cheyenne super 2 tone green and white ZZ6 - Th350 4/6 drop 20x8.5 / 20x10 Billet Specialties |
#14 |
How much clearance do you have between the headers and the ground?
1970 Chevy C10 "Under Construction" ![]() 2002 Chevy S10 V6 ![]() |
#15 |
1962 C-10
I'm usually on the 60-66 board, but here's a pic of my buddy's '72 with I believe a 2"-4" drop ( drop coils all the way around)...
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
#16 |
st1x10 I have about 4 1/2" to 5".
JOHN
#17 |
senior member
i live in alberta and dont have a problem with the airride, been a while since i been to saskabush are the roads really that bad there? im going to shaunavun (sp?) in a couple weeks maybe id be better thaking the DD
69 GMC bagged |
#18 | |
3' / 5' drop on 50 series tires. esll. ![]()
Tomorrow is for doing today's stuff. ![]() ************************************* This truck has just the right amount of energy for me! ![]() Author: Warren Lake .... (member) |
#19 |
No the roads aren't all THAT bad...but watch out, there are a few doozies!!
#20 |
Shaunavon is far enough south to still be good travelling. For a real thrill try hwy 571 (I think) that branches off 41 north and leads to Alsask...once you cross the welcome to Sask sign, better use both sides of the road! Try it for fun and adventure!
#21 |
That is the area where I grew up! (Close to Alsask) If you use hwy 21 & 44 HANG ON!!
1967 GMC 1/2 Ton - A Work in Progress ![]() Last edited by shlickster; 07-19-2007 at 01:12 AM. |
#22 |
I did the ECE 2.5" Drop spindles and the 4" drop springs in the rear... I love it! The tires are 275R60/15 at all corners.
Before and After shots.
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project. 1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver. |
#23 |
This is a 3/4 drop.
#24 |
![]() Join Date: Jul 2006
3/4
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
#25 |
Insert Title Here
heres mine
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
