Old 09-21-2002, 09:34 PM   #1
lukecp
Formerly yellow72custom
lukecp's Avatar
Rear End Yolk Replacement
When i picked up my truck from the tranny shop today (got a rebuilt TH350 put in it...shifts nice and firm ), the guy mentioned that my rearend yolk had a big chunk out of it, and the U-joint wasn't sitting quite right. I noticed the chunk when i changed the carrier bearing back in July, but i didn't do anything about it. So, how do i change the yolk in the rearend? It is a 12-bolt corporate, with 3.07 open gears, and coil springs if that matters. I already know how to remove the driveshaft. Thanks for the help!
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 09-21-2002, 11:24 PM   #2
minibike
minibike's Avatar
I used a two jaw puller on mine. No big deal. You should mark the orientation, and also the spot where the nut is on the pinion shaft. When you put it back together, you don't want it any looser or any tighter than it was. This will affect your ring/pinion alignment.
69 SWB
LT1/4L60E
www.classicplace.com
minibike is offline   Reply With Quote
Old 09-21-2002, 11:25 PM   #3
minibike
minibike's Avatar
Also, If you have to buy a new one, they are expensive. I have a used one I would be willing to sell, if needed.
69 SWB
LT1/4L60E
Old 09-21-2002, 11:41 PM   #4
lukecp
lukecp's Avatar
So i mark the yolk in orientation to the rearend, mark the nut in orientation to the yolk, take off the nut, yank off the yolk with a puller, and put everything in the same way it was before?
minibike, i may have already located a used one, but i'm not sure if it the correct one. I think they are different between the 67-70 trucks, and the 71-72 trucks. Mine is a '72. If this one isn't the right part, i will be interested.
Old 09-21-2002, 11:46 PM   #5
minibike
minibike's Avatar
The one I have is off of a 71 rear end. If you want it, it is $20 including shipping. Let me know if the other one doesn't work out.
69 SWB
LT1/4L60E
