Old 04-29-2002, 10:03 AM   #1
Fast68Chevy
Fast68Chevy's Avatar
Post wow, big engine code discrpancies!
wow, i got the front pad suffix stamping code off the engine thats stuck in the 82 trans am and its TBL, so i go to nastyz28.com http://www.nastyz28.com/sbchevy/spcode6.html and look it up and it shows to be a 350 engine of three different years, well i see that the oil stick is on pass side, so that means its 80 or newer, so ok its an 82 350, cool i suppose..
well i just got the frickin cxasting numbers off the back of block and they are 14010201
its a damned 80's 305 truck engined...
wtf... i measure cyl bores and i get roughly 95mm, IE 3.74" bore,...
dammit...
apparently cannot trust stamping code or nastyZ28 site has a typo error
[This message has been edited by Fast68Chevy (edited April 29, 2002).]
Fast68Chevy is offline   Reply With Quote
Old 04-29-2002, 10:15 AM   #2
MJN
MJN's Avatar
Post
When I get home from school I'll check the numbers. I have the books and I probably should buy the big block one soon. Hopefully I can figure out what wrong.
TBL: 70,71,72,79,82 truck 70,71,72 are 350 79 350 and 82 is 305
14010201: 305 80-85 pass,malibu,montecarlo, camaro,nova or 305 80-85 truck
Looks like a '82 305 truck with 150 hp (woo hoo)hooked to a manual LE-9rpo 1x4 carb
Hope this helps, guess nastyz28 is wrong on the stamped codes
[This message has been edited by MJN (edited April 29, 2002).]
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 04-30-2002, 12:57 AM   #3
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Post
I have the same problem with a 327 I bought recently. the casting numbers say it's 327, the crank numbers say 327, the stamped code on the front of the block says 307. I got that info from nastyZ28 as well. Oh well, 2 out of 3 aint bad.
Ol' Buck: '72 Chevy 1/2T 4x4 shortbox stepside 350/350auto on '84
ralleys and 31/10.5s
Angel girl: 67 Cutlass convertible
330, 3spd stick
Greener: 90 GMC Jimmy
350/auto
Chad Stephens
Orleans,NE
no name yet: 72 442 under serious construction
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
