i want to pull the a/c any advice
living in Texas makes me want to keep it but, its lowering my horsepower. and i find it as an eyesore under the hood. and if i wanted to sell the ac (compressor ect.) how much could i make?
never finish start another
Re: i want to pull the a/c any advice
Is it a working system? New a/c run 1000 to 1500, and are a lot more efficient. Are you going to part it or sell complete? There was a compressor that sold for 99 cents on ebay and claimed it worked! The brackets sometimes bring more than the components
yes it does work; i am just looking to lighten the truck in hopes of gaining a few extra horse's
![]() ***note to admin this is not a add i am just curious about how much i could make if i sold it*** |
Registered.........
Well, in all reality the A/C doesn't rob any horse power from the engine when it is off. Look at it as a rather large idler pulley when not in use, it does however affect horse power and fuel economy when it is in use.
Just thought that I should throw that in, in case it sways you to keep your A/C setup intact. It might not be the best looking thing under the hood - but it is nice to have on those hot humid days!
1966 C10 panel-400 small block/TH 350 combo Nothing is fool proof to a talented fool! Popcorn: Pops at exactly 444 degreese Expands to 44 times it's original size Has a 4 year shelf life |
Active Member
![]() Join Date: Jul 2007
Man, I wouldn't get rid of it if I was you. We've had some mild weather so far because of all the rain, but 100+ degrees are just around the corner. I'd sacrifice a few horses or mpg to have an a/c in those hot summer days.
You can always squeeze a few extra horses with engine mods but if you ever decide to sell the truck you can get more for it with A/C, for sure. |
I agree with the rest of the posts. If it works then use it! Wow one that does work
Have you thought about getting a smaller polished sanden? unit and aluminum brackets? That should clean it up and shed some pounds too. If you want your HP to go further, you could also trade the intake, heads and water pump for aluminum, manifolds for headers, and copper radiator for aluminum. If you're on a small budget, just phase it in a little at a time.
MOVE OVER
keep it intact, if you have a working unit its more valuable in your truck. you may not want to sell it today but you never know later. and I agree, if you dont run it, it aint robbing power.. arent there some attachments you can get that will temporally shut off the AC when you need more power? I think at one time you could get a AC cutoff switch for passing etc...
No matter where you are..... There you are... Buckaroo Banzi |
Careful as this is a what's it worth question and can be locked for that reason. Only subscribing members can ask what it's worth. FYI>
oh ok i was unaware.
Good luck selling if you take it off, I have been trying to get $200 out of mine and I have had no luck.
WTB this ad
My advice........Don't pull the A/C. Nothing worse than not wanting to drive your project after all the $$$ and work just because it's miserably hot outside. Now if this is gonna be a track only pickup, by all means rip it out!
#13 |
Agree with all of the above and would like to add that removing the entire setup won't save very much weight or gain you any HP.
Not sure what it all weighs but I have a complete setup in a big cardboard box that I can carry with not much effort. I say keep it original ![]() Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
#14 |
you must be nuts ![]() I am in Dallas and there is no way I would disconnect a working a/c. Just dont use it unless you need to. I agree it is a eye sore under the hood but gosh, this is Texas! ![]()
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
#15 |
![]() Join Date: Oct 2005
Keep It. Also remember that the ac helps with defrosting or defogging your windsheild. and beleive me, I just got through installing the factory ac unit and its well worth it because I have been riding around in my truck every day for the past 2 months and when its hot outside it really sucks not having the ac working.
1972 chevy cheyenne 10,nothing special at the moment,Its a work in progress, Working on the engine, paint and body,engine, paint and body,now its the suspenion, ahh hell I'm about tired of working on it. Maybe it will be a rat rod. ![]() |
#16 |
I'M TRUCK CRAZY!
Don't take it out if it works.
#17 |
If you're looking to free up horses, just pull the belt off. Your engine wont have to even turn the pulley. If you want to see how it feels to free up that weight, just leave your spare tire and jack at home and maybe shed the front bumper. Okay - those are really bad ideas, but you'd get the feel.
If it were me, I would leave the AC intact and look for a low-buck power adder to compensate for the weight. Others have given some great suggestions here (headers to add a few HP and drop weight, for instance).
67 C-10 LWB "Cow-butt-spotted" (neighbor's term) - work in progress. 350/TH400/3.73 67 Chevelle SS Clone ![]() |
#18 |
Like gain what, 2HP, if that? Not to sound like a dick, but this is probably one of the stupidest things I've heard.
#19 |
Your logic makes sense to me, but at the same time wait a month and your logic might change once it REALLY heats up! I live in Dallas too, and I won't drive without A/C.
The A/C might be an eyesore because it is dirty. Clean it up, paint/replace the brackets and it won't be an eyesore, but an eye catcher! An old truck with A/C??? People love it when they see it, and especially driving in it (assuming it is a driver). Before you do it, drive around town for a couple of hours with the windows down and do not turn on the A/C. ![]()
_______________ Thomas '78 Silverado '74 Monte Carlo '47 Teardrop Trailer East Texas Classics Local Club |
#20 |
ok another question how do i dressup that black box
#21 |
Clean it. I've seen pictures of guys under hood heater/AC boxes that look pretty sharp.
I never did understand the shaved look on the firewall. But it is your truck, do what you want to it. Just don't post here that you vented that R12 to the atmosphere. That is against the law.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
#22 | |
![]() Join Date: Nov 2004
![]() I just spent some major $$$ on a vintage air set up and LOVE IT. I haven't noticed any HP drop or loss of power. I still don't have my dash back in the truck so fuel economy is unknown.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#23 |
Chief Honcho In Charge
Do you have an HEI distributor...might give you a nice boost
1992 1500 4x4 Shortbed 1984 Ford F250 Supercab Longbed 6.9L Diesel 1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C 1971 VW SuperBeetle 1960 Wife 1984 Son 1986 Son 1989 Son Previous Trucks 1967 C10 SWB (1980-1981) 1971 C10 LWB (1998-2004) |
#24 |
Keep it. Switch to an electric water pump and electric fan to gain HP. Just added an aftermarket A/C to my '67/283 and the mileage only dropped 1/3 of an MPG and that's here in Houston, so it runs all the time. Was unpleasant drivin' it before that.
Good luck, JD |
#25 |
buy a polished compressor and give me your old one with the bracket...then we will both be happy!
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
