Old 07-18-2007, 09:55 PM   #1
salazar44
65 - Chevy C10
salazar44's Avatar
Wire Haness Kit Experiences
Wondering who has used different wiring harness kits and how their experiences were. Im looking to do a complete re-wire and want to know what to look for and what to look out for. Thanks guys.
VIC
One Repair Leads to Another!
http://vix65chevyc10.blogspot.com
salazar44 is offline   Reply With Quote
Old 07-18-2007, 10:51 PM   #2
62 short step
62 short step's Avatar
Re: Wire Haness Kit Experiences
I used an EZ wiring harness, it was an easy install. Followed all the steps and I didnt have a problem. One pointer, make sure all your connections and grounds are good.
62 short step is offline   Reply With Quote
Old 07-19-2007, 12:38 AM   #3
salazar44
65 - Chevy C10
salazar44's Avatar
How do these kits connect to our dash cluster?
VIC
Old 07-19-2007, 12:49 AM   #4
19GMC63
19GMC63's Avatar
I used the painless kit, and overall, I was pleased. It did away with stock connectors(firewall, rad support and whatnot), which in my eyes, is a good thing. The less connections the better.
It came pre-bundled in different sections. Just cut to length and attach connectors. The dash light sockets are pre attached. Kit also has a 50 amp maxi-fuse to protect the whole harness.
I went w/ a 12 circuit, but now I wish I would have went with the 18.
I also used painless's powerbraid wire loom, it looks great and has a high melting temp better than regular convoluted loom.
19GMC63 is offline   Reply With Quote
Old 07-19-2007, 03:39 AM   #5
salazar44
65 - Chevy C10
salazar44's Avatar
how does it hook up to the dash and ignition? is it more of a universal type connections? If I get the painless 10112 does it come set up for HEI?
VIC
Old 07-19-2007, 07:17 AM   #6
64GMCHorsepower
Justified!
I bought an EZ kit, and it has plugs for the ignition, and also for the steering column. Getting ready to put it in now, so I was looking at it last weekend.....
I bought the 18 circuit, so I will have several left over.......what with no power windows, power locks, A/c ....you get the picture
looks like a pretty complete set, and every wire is labeled......
Chad
Chad
1964 GMC Fleetside Shortbed....350/700R4 tranny
64GMCHorsepower is offline   Reply With Quote
Old 07-19-2007, 08:50 AM   #7
65stepside
65stepside's Avatar
I used the American AutoWire kit. It was easy to put in, and pretty much is exactly like the original set. All the connectors are just like the stock ones. However, I've had issues with the front marker lights, the taillights, and the light switch in the dash. this one also gave the option of HEI or the stock coil.
1930 Olds 5 Window Coupe
1960 Chevy 1/2 Short Stepside on 1965 Frame 350/350
1960 Chevy 1/2 3'' Chop Short Stepside "FOR SALE!!!"
1966 Toronado
1971 Cutlass
1972 442
1978 Chevy 1/2 Long Fleetside
2001 Dodge 2500
65stepside is offline   Reply With Quote
Old 07-19-2007, 10:54 AM   #8
salazar44
65 - Chevy C10
salazar44's Avatar
19GMC63 and Chad, do to painless or ez kits come with HEI option?
19GMC63, did you get the kit?
65stepside, what type of issues are you having with your lamp harness?
Thanks for the help guys!
VIC
Old 07-19-2007, 12:37 PM   #9
Musclerodz
American Autowire has a Update harness specifically for these trucks. Has options to hook to all the factory stuff or aftermarket parts. HEI option, and comes with alot of the original style connectors along with a new ignition, headlight, and dimmer switch. No better choice on the market. Kit retails for $529, I sell them for $499. Or you could just go back completely stock with all OEM correct harnesses from AAW. More expensive, but easier to install and each harness is concours correct.
Mike
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 07-19-2007, 12:52 PM   #10
hewlett2002000
hewlett2002000's Avatar
i got my painless harness from a swap meet for $100. i couldent pass it up, brand new in the box. it was for a newer model gm car or truck so it had the column ignition plugs. it was an 18 circuit so i had plenty of wires left over. it took me two days to get it all in and working and it works great. i just cut the column connector off and ran the wires to my ignition switch. it was easy. everything works great and now i dont have shorts everywhere.
John
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 07-19-2007, 01:04 PM   #11
SIR
SIR
SIR's Avatar
...if you can do it stay away from "crimp-on" connectors,I've had them come loose or make a bad connection or even fall off !! yes they have there place,but with solder and shrink wrap you know the connection is good...
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline   Reply With Quote
Old 07-19-2007, 03:41 PM   #12
onebad'65
I re-wired my '65 with a painless wiring harness kit and it wasn't all too complicated. The wires are labled and color coded just as the factory which made it quite simple. I know if you order directly from painless wiring, you'll pay more for the kit but I went through JEG's and saved about a $100 which was the best deal I could find at the time. I bout the 12V 18-circuit harness and it's set up for A/C, electric colling fan, electric windows and door locks, and all the basic accessories. I'm not sure if that helps or not but painless would be the best suggestion I would have for anyone that's trying to rewire their vehicle by themselves.
onebad'65 is offline   Reply With Quote
Old 07-19-2007, 03:42 PM   #13
19GMC63
19GMC63's Avatar
the painless kit does come with an HEI wire. The wires attach to the ignition individually, so there's no plastic connector or anything. The ignition wires do have the connectors on out of the box. As far as dash goes, everything is individual. I have no idea how chevy dashes are, but my GMC had the printed circuit, so it just did away with the circuit, which is fine by me.
I got mine and the loom from Summit Racing.
Old 07-19-2007, 03:46 PM   #14
19GMC63
19GMC63's Avatar
oh, and regardless of the harness, make sure you have good grounds. That would(should) be your only problem with any new harness, if installed correctly.
Old 07-19-2007, 06:38 PM   #15
Paul Sek
Hi
I used American Autowire and it worked out good. My only problem was ground. I ran extra ground wires for every light. It was a little extra work but they shine brightly now. good luck
Paul S
Paul Sek is offline   Reply With Quote
Old 07-19-2007, 07:30 PM   #16
62 short step
I have Dolphin guages in my truck, so I'm not real sure about that one.
Old 07-20-2007, 12:47 AM   #17
65stepside
65stepside's Avatar
My issues: Its been awhile since i've messed with it, but it consisted of the rear lamps only coming on at half brightness and no blinkers in the back. And the fronts not blinking. I've tried switching the wiring and grounding the heck out of everything, and got nothing yet, oh and it fried a couple of light switch because of a set of wires that were switched around in the light switch cluster. still a work in progress..
1966 Toronado
1971 Cutlass
1972 442
2001 Dodge 2500
Old 07-20-2007, 01:08 AM   #18
PrerunnerRob
PrerunnerRob's Avatar
On my 2001 Silverado, the liscence plate light ground grounds the whole rear harness if that helps any!
PrerunnerRob is offline   Reply With Quote
Old 07-20-2007, 07:19 AM   #19
64GMCHorsepower
Justified!
Well, i put an EFI engine ine my truck, and it had a seperate harness for the engine, the dizzy hooked up throught that......so I don't know about the HEI hook-up....I found severeal connectors that I haven't used yet, and I think 1 might be the hei hook-up
BTW, when everyone upgraded to new gauges ( I have a Dolphin set also)
did you use the old dash panel, or buy one somewhere....
I made 1, but don't have a bezel around it, just a piece of aluminum with holes machined in it......
Chad
Chad
Old 07-20-2007, 01:15 PM   #20
SIR
SIR
SIR's Avatar
...I had the bezel chromed,the gauges and gauge panel are from "haneline"...
Old 07-20-2007, 04:17 PM   #21
Ogilthorpe
Ogilthorpe's Avatar
I used the American Autowire kit - just finished it a few days ago. It's pretty pricey in my opinion, but it's a very complete kit with easy to follow instructions and all wires marked. It allows you to wire stock/aftermarket gauges, HEI/points ignition, stock or 1-wire alternator.
Ogilthorpe is offline   Reply With Quote
Old 07-20-2007, 04:45 PM   #22
mbgmike
You really won't have any problems with any of the major brand harnesses. We sell Painless kits and also install them on customers cars. I like Ron Francis kits for my own stuff, but thats just my personal opinion. (I like the little clip on terminals) Their really is not much difference in any Mfg's kits as a whole. mainly the fuse panel. Some panels have the option to switch from battery hot to ignition hot etc just by sliding the fuse etc.
mbgmike is offline   Reply With Quote
Old 07-20-2007, 04:53 PM   #23
mbgmike
Chad
We sell these but right now only fit autometer. They can be powdered coated to match dash or painted. They come in chrome plated also. It's a two panel item. The gauges mount to the inner panel and they outer covers up the ring around the gauge for a more flush look. With LED's and shift indicators for manual or automatic trannys
Old 07-20-2007, 10:39 PM   #24
64GMCHorsepower
Justified!
Mike, will that fit a GMC dash....I would have to fill i the knob holes on the bezel otherwise since all my control knobs are on the front panel under the dash...
Chad
Chad
Old 07-21-2007, 12:21 AM   #25
19GMC63
19GMC63's Avatar
no, they are different.
I still haven't found anyone that makes bezels for GMC's. All the custom one's i've seen were homemade.
