07-19-2007, 12:51 AM | #1 |
transfer case
Hi to every one I have this 72 blazer and I put a 6.0 charged with a 4l60e and not sure which transfer case put in . It was a allwheel drive and I pulled it off. A friend and I was messing around he had a np208 w/right hand drop and it bolted rite on but it dont have VSS on it like the tc.
07-19-2007, 01:37 AM | #2 |
Professional Grade
Re: transfer case
An NP241 fits the bill perfectly!
It is nearly identical to an NP208 in appearance, is identical as far as dimensions go, uses the same shifter and bolts straight up anywhere a 208 will, but is available with a VSS, and has a slightly better low range as well. You can get them with both 27 and 32 spline input shafts, which are interchangable with relatively little work as compared to other t-cases. You can buy them from Blazers, Jimmies, Suburbans and Crew Cab pickups from 89 - 91. In 89 they have a speedometer cable drive like the old transfer cases, but in 90 it was switched out to a VSS. If you find an 89 case, you can swap on a VSS tailhousing without any modifications. From NP241 has been available in the half ton trucks since 88 but is a driver's side drop, so you have to get it from the old body style trucks with the solid front axles Despite being a 3 year only case, they arn't really that hard to find, but they are a bit more expensive. I paid 500 for a rebuilt 89 case since I need the speedometer cable drive until I make my 6.0L swap. Used VSS cases would go for closer to 300 or so.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) Last edited by Russell; 07-19-2007 at 01:40 AM. |
07-19-2007, 09:29 AM | #3 |
Post Whore
Re: transfer case
Welcome to the board. Be sure to jump over the the 69-72 Blazer forum and post some pics of your project.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
07-19-2007, 09:36 AM | #4 |
Re: transfer case
Welcome to the board,and I agree with Yukon Jack,post some pics in the Post Your 4x4 Pic thread and also in the blazer section when you get a chance
07-19-2007, 11:26 AM | #5 |
Re: transfer case
thanks for the info and will post some pic today if I can do it. This is a very good forum. thank you guys again
07-19-2007, 02:12 PM | #6 |
Blazerless
Re: transfer case
You can also get a speedo cable to VSS adapter. There are a few sources for this. Try Bowtie Overdrives or Painless Wiring. That's what I used for my 700R4/350TBI swap. The EFI needs VSS signal, and I was ablt to keep my stock speedo. Cheaper than a t-case swap too.
72' K5 Blazer 4x4 350TBI/700R4/NP205 3/4 ton diffs. Daily driver. SOLD 69' Beaumont 388/700R4 11.70@116 77' Bronco, Wife's mall cruiser/poser 4x4. Capable but too pretty to go offroad. |
