The Few, The Proud
![]() Join Date: Jun 2007
WIW 3/4t Axles
I'll be removing the 3/4t axles from my truck here shortly to replace them with some 1/2t ones from a donor truck.
What are these axles worth? I'm unsure of the gear ratio at the moment. Dana 44 closed knuckle w-drum brakes up front Eaton/HO52 w-drum brakes in the rear
Shannon Last edited by sdailey; 07-19-2007 at 09:30 AM. |
Re: WIW 3/4t Axles
I'd say $150-$200 for the pair.The rear would be worth the most since the front is a closed knuckle.
The Few, The Proud
Re: WIW 3/4t Axles
Thanks Dustin.
Shannon |
Re: WIW 3/4t Axles
I`d say around $300.A pair of 8-luggers is a cool upgrade for the zillion 1/2tons out there.The slightly antiquated axles wouldn`t be such a drawback on a custom-build.They also have a value to the limited original restoration crowd.You may need to sell for $150-200,but let them go to use and not scrap,whatever you do.The parts are worth $150-200.
![]() Join Date: Oct 2006
Re: WIW 3/4t Axles
How much for the eaton rear end?
Re: WIW 3/4t Axles
I a'm also removing my closed knuckle axle out of my 67 3/4 ton 4x4, I will have a spare 3/4 ton closed knuckle with no new home.
65 tripower conv 4spd gto, 66gto, 67 gto 65 lemans conv 4spd 69 firebird conv. 67 c20 4x4 |
The Few, The Proud
Re: WIW 3/4t Axles
Shannon |
