Old 07-19-2007, 12:25 PM   #1
semperfidoordie
Fix It Till It's Broke
semperfidoordie's Avatar
Gauges not working
I was wondering about how to get my gauges working in the dash. Right now the only ones that work are the speedo and fuel gauge...put a new thermostat in thinking that would at least fix temp but it didn't...what the heck?
Tony
Black Beauty: 85 C-10 SOLD!
Great White: 69 LWB Custom Camper/20 SOLD!
Blue Dragon: 72 K-10 SOLD!
The Tank 77 K-10 KIA
panhandler62: Just don't search for "trannys" no matter how hard yours shifts -- you just won't get what you are looking for.
I Made The Official So Cal Board Meet
semperfidoordie is offline   Reply With Quote
Old 07-19-2007, 04:34 PM   #2
dave2953
Dave's not here, man
dave2953's Avatar
Re: Gauges not working
Are these factory gauges?
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 07-19-2007, 04:51 PM   #3
GMC AMI
GMC AMI's Avatar
Wink Re: Gauges not working
Well I guess you know that the thermo has nothing to do with the engine temp gauge now. If sending unit on motor is correct and working than the dash gauge would be at fault as long as wire to motor is good. Oil pressure has a mechanical line that runs to the dash gauge from the back of the motor right behind the intake manifold by the dist.
If not blocked then it should work or the gauge is messed up. If no oil pressure than the motor would not run for too long before problems lock you up. Good luck.
GMC AMI is offline   Reply With Quote
Old 07-19-2007, 05:36 PM   #4
semperfidoordie
where's the wire to the motor go? and I see where the oil presure line is...it's like a female end coming out of the fire wall right?
Tony
Old 07-19-2007, 05:37 PM   #5
semperfidoordie
yes they are factory gauges
Tony
Old 07-19-2007, 06:24 PM   #6
dave2953
dave2953's Avatar
Do you mean the male spade on the oil pressure sending unit just behind the dizzy? I think that's where the wire attaches for the idiot light. Is there a metal line that runs into the cab and attaches to the back of the gauge?
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
