Old 09-22-2002, 01:48 AM   #1
BADASS2001CHEVY
What size lug patern?
When converting a 67-72 to 5 lug what size is the patern? Somebody said its not 5 on 5?
http://www.dfwstangs.net/hosting/BAD.../badasssig.jpg
74' Camaro SBC/TH350 Thats all you need to know.
Want some?...Come get some!
BADASS2001CHEVY is offline   Reply With Quote
Old 09-22-2002, 11:44 PM   #2
low 84
low 84's Avatar
5 on 5, who is somebody?
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 09-22-2002, 11:51 PM   #3
BADASS2001CHEVY
Guy on another board, why? Is it the same as like a 90's model Chevy?
Old 09-23-2002, 02:25 PM   #4
low 84
low 84's Avatar
i was just curios who told you that and where they get there info from......yes it is 5 on 5. same as the 90's 5 lug trucks. you can swap wheels back and forth between them. only difference is that most of the 90's trucks have metric threaded wheel studs and the 87 older trucks have standard threaded studs. so you can't interchange lug nuts. there are a some early 90's trucks with standard studs, but most are metric
'05 1500 Crew Cab
RIP
Old 09-23-2002, 06:02 PM   #5
BADASS2001CHEVY
Really? I cant believe some people why spread false info? Thanks bro I needed some help thanks
Old 09-23-2002, 09:54 PM   #6
68_c10_on20s
68_c10_on20s's Avatar
bolt pattern
yeah its 5 on 5 i have some 80s rally rims on my 68 but i also have a 96 ond the wheels will fit on it the diffrence is the bolts are diffrent on the late models cause there metric but they will all interchange
68_c10_on20s is offline   Reply With Quote
Old 09-23-2002, 09:59 PM   #7
BADASS2001CHEVY
Cool
