Old 07-19-2007, 01:07 PM   #1
hellrazrblade
Purple People Eater
hellrazrblade's Avatar
Offroad Maintenance
What sort of maintenance do yall do on your trucks after you pass through deep (over the axle) water/mud? I'm trying to figure out what I should do to keep the axles happy and undamaged. I tried to find some other threads on the subject, but I must not have been using the right phrases.
1971 K5 Blazer 396ci/TH400/NP205/Dana 44/GM 12 Bolt/38" TSLs
2004 Chevy 1500 4X2 X-Cab 327ci
hellrazrblade is offline   Reply With Quote
Old 07-19-2007, 01:18 PM   #2
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: Offroad Maintenance
Raise up you axle vent hoze to keep water from getting in that way.
After mud and water crossings, i take the front hubs apart and clean them. I find that its darn near impossable to keep everything out. Before i go wheeling i also put duct tape on the end and around the outside of my hubs. They are known to leaking. (1/2 ton hubs). And i grease all my fittings afterwards to force out any water.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 07-19-2007, 09:41 PM   #3
CrashEd
72 chevy
CrashEd's Avatar
Here is one mod i am doing to my 4x4 it will save a lot of time on off road maintenance.
Water proofing a dana 44
If you extend the breather tubes on the axles taller than your engine air intake and have good seals then it wont let in much water.
Also get all greaseable ujoints helps too.
Ed
CrashEd is offline   Reply With Quote
Old 07-22-2007, 07:34 PM   #4
hellrazrblade
Purple People Eater
Thanks for the replies. The water proofing link is interesting, and once I have a little time, I might give it a shot.
