Old 07-19-2007, 05:51 PM   #1
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Question Spark Plugs
Hay yall,
I was hoping someone could tell me how to pick a hotter plug then what I have. I am not trying to do this. I am just curious. How do you tell if it is a hotter plug?
LOW DOUGH is offline   Reply With Quote
Old 07-19-2007, 05:56 PM   #2
rambler
MOVE OVER
rambler's Avatar
Re: Spark Plugs
just have the parts store look it up for you, they should know by the book and the part numbers on the plug. I typically go to a hotter plug on a older engine that is using oil... (which is usually all of my vechicles...)
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 07-19-2007, 06:03 PM   #3
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Spark Plugs
For AC plugs, I have simply gone by the numbers on the plug. If the book calls for an R45TS, an R46TS is the next hotter plug. A 44 would be one range cooler than the 45.
Back in my Mustang days, I think their numbering went by tens. Seems like I remember a BF32 as the colder version while a BF42 was the correct plug.
As in all my posts, I reserve the right to be wrong without any warning.
Member Nr. 2770
Old 07-19-2007, 07:37 PM   #4
JimKshortstep4x4
Re: Spark Plugs
Reaper 71,
Here is a link to the AC spark plug information that explains the codes on the plugs including the heat ranges.
http://www.acdelco.com/parts/sparkpl...tification.jsp
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 07-19-2007, 07:57 PM   #5
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Re: Spark Plugs
Thanks JimK, that was good info.
I put in an 85 Chevy Truck and got AC spark plug R43TS. Does anyone know what heat range the 3 indicates in the AC part number?
What would the heat range be for R41TS - R49TS, if there are such part numbers?
Old 07-19-2007, 09:17 PM   #6
Aarons72s
Re: Spark Plugs
Jim thanks for the great link.
Aarons72s is offline   Reply With Quote
Old 07-19-2007, 09:23 PM   #7
68gmsee
Active Member
68gmsee's Avatar
Re: Spark Plugs
Not sure if you are asking how you can tell the difference by looking at them but theoretically the more the ceramic part sticks out of the plug the cooler it is-the gases/air cools the plug faster. The more recessed it is into the plug the hotter it is-not as much gases/air gets to the ceramic part.
68gmsee is offline   Reply With Quote
Old 07-19-2007, 10:13 PM   #8
68gmsee
Active Member
68gmsee's Avatar
Re: Spark Plugs
Ooops, reread my info on plugs and I remembered it wrong. Its the recessed lenght of the insulator inside the plug that makes it hotter.
Here's a pic that explains the hot vs cold.
This is the site I got this from site:
http://www.dansmc.com/sparkplugs1.htm
Old 07-19-2007, 10:48 PM   #9
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Re: Spark Plugs
More good info! Thanks 68gmsee
Old 07-20-2007, 12:16 AM   #10
manimal
manimal's Avatar
Re: Spark Plugs
AC plugs suck IMO! As well as Champion. Autolite plugs are the way to go. But again thats JMO.
-Lance
If you use AUTOLITE,the parts store book will have a cross-reference in the back and it will put you in a specific heat range,then you can go up/down from there.
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 07-20-2007, 12:22 AM   #11
lbpd719
Zappaphile!
lbpd719's Avatar
Re: Spark Plugs
I have had better luck with Bosch and NGK's than Autolite, Champion, or AC..
bult I will agree Champion and AC plugs tend to suck! they just dont wear the electrode efficiently..
But if you are having problems with plugs dying out, and you DON'T think it's oil related, pick up one of the Color-Tune kits. they can really tell you how "on" your setup is on the fuel side, without a whole lot of guess work. They also tell you if you are leaning out to quick and need to do some jet swaps..
A "must have" for the weekend tuner who doesnt want to invest in a gas analyzer.
1969 C20 LWB Camper Special - The Beater..
1998 Cheyenne V6 - 4/6 Drop - For The Son
lbpd719 is offline   Reply With Quote
Old 07-20-2007, 11:52 AM   #12
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Re: Spark Plugs
Thanks for the comments guys. Anyone with some more info?
