Old 07-19-2007, 06:42 PM   #1
1971pumpkin
67-72 smooth firewall,but still have A/C
Is there anyone running a 67-72 chevy with A/C and still having a smooth firewall(any Pics),if so where do you run you fittings through the firewall to you A/C compressor and still have that smooth clean look.and what systems are you using.i was looking into the Gen II from Vintage air,any suggestions/Pics.
1971pumpkin is offline   Reply With Quote
Old 07-19-2007, 08:19 PM   #2
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Re: 67-72 smooth firewall,but still have A/C
I have attached a picture from Good guys. Not my truck so I can not help anymore than what you see, but it is what you are looking for.
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 07-19-2007, 09:41 PM   #3
SkylineNXS
SkylineNXS's Avatar
Looks like in the pic above they just ran the fittings right under the smoothed part of the wall, u can barley see three tubes right "above" the compressor in the pic, and im assuming they used a vintage air system...
2000 GMC Sierra EXT Cab Short 4x4, finally mine...
1966 C10 SWB Fleet, 250 I6, three on the tree....
Previously Owned....
1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4....
1972 Chevy LWB Fleet 350/350
EXTENDED CAB ALL THE WAY!
.._..~...-...._...____
.._..-...______|_|__\____
..-..~.|_(O)__|_|__|_(O)]
SkylineNXS is offline   Reply With Quote
