Old 07-19-2007, 09:36 PM   #1
chadfowler
brake problem
i have a 72 chevy truck with power brakes and sometimes the pedal goes to the floor and then i can pump it once and it has a good pedal and then it will work good but every once in a while about every 8-10 pumps it will go to the floor again does anyone know why this is happening i think it is the master cylinder but wanted to see what yall thought befor i bought one
chadfowler is offline   Reply With Quote
Old 07-19-2007, 09:38 PM   #2
st1x10
st1x10's Avatar
Re: brake problem
I would guess the master cylinder
1970 Chevy C10 "Under Construction"
2002 Chevy S10 V6
st1x10 is offline   Reply With Quote
Old 07-19-2007, 09:54 PM   #3
69RAT
Re: brake problem
also check the booster, if its not getting enough vacuum it'll act that way.
'69 Chevy CST#'s 396/TH400, A/C
69RAT is offline   Reply With Quote
Old 07-19-2007, 10:22 PM   #4
68gmsee
Active Member
68gmsee's Avatar
Re: brake problem
I've had that happen on my 69 Chevy and my Tahoe. On mine, both times it was the master cylinder.
68gmsee is offline   Reply With Quote
Old 07-20-2007, 12:04 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: brake problem
if the booster isn't gettin enough vac.. it'll use the reserve vac in that huge booster... and if that runs out, it'll get hard.
Master for 99% sure.
