Old 07-20-2007, 01:22 PM   #1
matthufham
5 inch rear drop question
without lowering blocks i have less than an inch from the bump stop. did yall cut off the bump stop?
matthufham is offline   Reply With Quote
Old 07-20-2007, 01:54 PM   #2
71see10
Worthless
71see10's Avatar
Re: 5 inch rear drop question
I have 5 inch drop springs on mine,I left the bump stops and do not bottom out but I do not carry a load in mine!!!!
71see10 is offline   Reply With Quote
Old 07-20-2007, 02:03 PM   #3
raggedjim
raggedjim's Avatar
I have a 6" drop and I cut mine down.
Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 07-20-2007, 03:44 PM   #4
GSFMECH
On the road
GSFMECH's Avatar
I have a 4/6 drop and had to cut mine down as well.
Mike
Mike
Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos
72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works.
My new build thread "Castro"
https://67-72chevytrucks.com/vboard/...d.php?t=820934
My old build thread, the blue truck
http://67-72chevytrucks.com/vboard/s...d.php?t=271489
www.louisianaclassictruckclub.com
GSFMECH is offline   Reply With Quote
Old 07-20-2007, 04:35 PM   #5
72 Cheyenne402
72 Cheyenne402's Avatar
I have a 4" in mine and everytime i put a load on it it drops but doesn't hit the bump stops. I am thinking about bagging the rear. I am installing a rear fuel cell and i don't know if the rear spring will sag if I put a load on it with the fuel cell. bagging the rear should prevent it.
1972 Cheyenne 402 LWB
2005 Silverado X-Cab 5.3L
2004 John Deere L120 20HP B&S
72 Cheyenne402 is offline   Reply With Quote
Old 07-20-2007, 04:51 PM   #6
faribran
yes.. .putting the gas tank in the rear plays a part... esp. with a full 25 gals.
with a 6in drop in the rear the bump stops need to be cut..otherwise its a jolt to go over railroad x-ings
faribran is offline   Reply With Quote
Old 07-20-2007, 08:05 PM   #7
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
Thumbs up Re: 5 inch rear drop question
Mike
Nice truck, I like the stance & the rake.
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
