Old 07-20-2007, 01:59 PM   #1
liljon285
That Guy
liljon285's Avatar
Problem with my radio
Hey everyone...i just got my truck running and i wanna work on the system now....a while back i had a pioneer but i switched it with my dad for the newer model of that same pioneer and i had pluggged it in and worked fine...now a few months later and a new engine i went to turn it on and at volume 1 it started making thois annoying screech...i checked al the wires everything is perfect. So then i got my dads radio(the old one i had...which by the way have the same plugs so no wiring was needed) and hooked it up to my truck and it works perfect but i hooked up the radio that does the screech to my dads truckj and it seems to work better than in my truck but yet the volume isnt working lol. Is the radio fryed?
1978 Chevy Scottdale Stepside, 3rd engine- 350c.i. built with cam and lifters, holley 670cfm carb. and intake,heads shaved .60. Truck is a project, and I am its restorererer!
liljon285 is offline   Reply With Quote
Old 07-20-2007, 02:59 PM   #2
liljon285
That Guy
liljon285's Avatar
Re: Problem with my radio
By the way this is it(the one thats messed up)
Old 07-21-2007, 06:15 AM   #3
AceX
>130dB Moderator
AceX's Avatar
There is a truck audio section a little ways futher down the forum list.
The screeching you are hearing could be many different things. What I would do is take a voltmeter and take measurements of the current flow on the old headunit vs the new one. That will help us diagnose what is going on.
If I had to guess, its probably a weak ground. Probably somewhere in the engine bay.
EDIT: Are you running an amplifier?
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 07-21-2007, 09:18 AM   #4
liljon285
That Guy
liljon285's Avatar
To the radio no...the subs yes...but i noticed it before i hooked up the subs or the amp..so it kinda has nothing with the amp or subs.
Old 07-21-2007, 01:51 PM   #5
streetstar
streetstar's Avatar
They make trash cans for radios like that.
Unless you bought it at Wal Mart within 90 days-- then you can just go get a new one-lol
streetstar is offline   Reply With Quote
Old 07-21-2007, 02:46 PM   #6
liljon285
That Guy
liljon285's Avatar
I doubt they make trash cans for brand new pioneer radios lol...i only heard it once then i had it off for months with the whole new engine thing now i got the engine in and everything is perfect yet the radio goes crazy. And i just had my amp go crazy on me now luckily i had another less wattage one so now im running my old radio which sounds aweomse with a lesser wattage amp which still sounds good i think ima leave it like that...but now i gotta buy my dad a radio lol.
Old 07-22-2007, 11:10 AM   #7
streetstar
streetstar's Avatar
send it back to Pioneer if its that new --- they might send you a new one --- or fix the problem with that one - either way might be a winner.
Have you run it on a bench yet though? Just take it out completely and hook some speakers up to it and run it with a jumper from a battery and ground
Old 07-22-2007, 03:00 PM   #8
AceX
>130dB Moderator
AceX's Avatar
If it's messing with the amp too, You've more than likely got a bad ground somewhere...
Living Life @ 130dB
RIP El Jay
