oops, greattt!
the po of the '72 can't find the keys for it, so i went and got a new ignition lock cylinder. only to find that you can't take the old one out unless you have the keys. so does anyone have any ideas or know how to do this with out tearing up the ignition switch and chrome bezel(which i couldn't get to come off either) it feels like it will un screw to a point but won't come seperate from the switch part. if i can't get it out without tearing it up then i'll just wire everything in with indivdual toggels and call it even.
Rottenwood Garage Member
Re: oops, greattt!
There are MANY archive posts about this.
Easiest way is to unplug the wirring harness from it and take a saw zaw and cut the old one out (in half) from the back. It will come apart and you can slap the new one in. 10 min job. |
Re: oops, greattt!
I have used a drill and a large bit to get the switch out before. Its not a big deal to get it out, just takes alittle work.
Re: oops, greattt!
Do a search for LocDoc. He is your best bet to doing this with a lot of damage.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
Re: oops, greattt!
doesn't the key actually just push a button in the back of the cylinder? i was thinkking you could use a paper clip or somthing.
the 50"s chevy's could be pulled with a paper clip.....used to piss a buddy of mine off, great fun!!
"spiiiider pig, spiiiiider pig, does whatever spiiiider pig does. " |
#6 | |
huh ???
Re: oops, greattt!
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
The Older Generation
Re: oops, greattt!
Check out this thread from yesterday..... ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=250254 Or this one from a couple of days ago..... http://67-72chevytrucks.com/vboard/s...d.php?t=250193 LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 07-20-2007 at 11:16 PM. |
