Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 07-20-2007, 09:33 PM   #1
JAKES 68GMC
Aluminum slot wheels rule...
Speaker wires?
I'm getting ready to wire up a radio/cd player in the GMC. (don't worry, I didn't cut the dash) Do I need to use special speaker wire to wire the speakers up to the stereo? I got ready to wire them, but the little bit of wire the speakers came with was a lot different than the wire I had, it had 1 little wire in the middle versus a lot of little wires like I'm used to.
Thanks for the help.
JAKES 68GMC is offline   Reply With Quote
Old 07-21-2007, 12:14 AM   #2
wannabelow
Re: Speaker wires?
it dont mater but i like to use 12gauge for it just incase i want to upgrade later that way i wont have to run more wire later.but 14 would be fine i would think
as to the one wire after you strip it,to the "lots of little ones" all the same ones just smaler and it depends on the wire gauge
wannabelow is offline   Reply With Quote
Old 07-21-2007, 12:46 PM   #3
72 cheyenne pdx
72 cheyenne pdx's Avatar
Re: Speaker wires?
w/WannaBeLow - unless you are only using 5.25 size speakers or smaller w/deck power. If are not going to ever upgrade and put these on an AMP in the future, you can get away with 16ga or 18ga wire. Anything larger than a 5.25 I would go ahead and use 14ga or larger depending on what that speaker's function/wattage will be running.
Good luck
72 cheyenne pdx is offline   Reply With Quote
Old 07-21-2007, 07:23 PM   #4
JAKES 68GMC
Re: Speaker wires?
Yep, I got some 5.25's. I have some fairly heavy gauge wire here, I'll just use that. Thanks for the help guys.
