![]() Join Date: Aug 2006
Need some pictures or advice
Well all day i have been messing around with my bed trying to figure out how i am going to mount the bed and how am i going to get clearance for the tires in the bed. I was hoping someone had some pics of what they had to notch out to make room for the rims and tires too tuck. I am thinking about cuting out the inside of the bedside then making some little braces to support the inner side of the bedside. I hope that makes sence. Also was curious on those who have raised the floor of there bed. Did you make new angle brackets for the wood to bolt to or did you cut off the originals and relocate them? One more question. Since i sold my original frame i am not to sure how the bed bolts to the frame. I know i have to make brackets but not sure where they go. Does anyone have pics of there bed before they put wood in so i can see how it is supported. Man i have alot running through my mind right now so sorry if some of this didn't make much sence.
Josh
(Project truck) 1970 C10 under complete transformation ![]() My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
Re: Need some pictures or advice
Here are some pics to help everyone on what i need help with. My thought is that i could notch out the innerside of the bedside to allow room for the tire but wasn't sure if that was what everyone was doing or does everyones wheels are narrow enough that it clears the inner side of the bedside. I hope that makes sence. Any comments would be much appreciated. Thanks
Josh
If I remember n2billet cut out that area where the tire is rubbing on his truck. I don't know if he cut it out completely or not. Maybe he or SCOTI or N2TRUX will chime in.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
And here ya go...... Lucys rear slice
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Junior Member
Yep.... I got the same issue. Thanks for the pics! They will help.
That is exactly what i was looking for. Thanks you so much. I was going crazy trying to figure out what to do and that never came to mind. I am going to go cut out my inner bedside right now. Thanks alot!!!!!
Josh
Ever heard of Beech Island??
heres a pic of my bracketts, thats a sweet truck
So there is just 3 support braces for the entire bed? Do they bolt to the inner bedside below the wood right? Thanks alot for that pic. It helps out alot!!!!
Josh
Village Idiot....
abadsvt- you might want to raise the tubs up as your doing the inners. It looks like your truck is a lot lower than Lucy.
![]() Maybe he or SCOTI or N2TRUX will chime in. Ask Scoti or N2trux ? Why not ask me? I'm the one that did it! ![]() Last edited by n2billet; 07-22-2007 at 05:01 PM. |
abadsvt, that is my step bed, but I am pretty sure the bracketts are in the same positions as fleet. I also put some 1" angle iron on the outside of the frame to fill the gap near the tires, like this
They seem to post more than you. I figure your very busy, but I did put you first in that sentence! ![]()
#12 | |
#13 | |
Or sitting around the hospital emergency room...... or . . . .....
#14 | |||
Village Idiot....
![]() Quote:
#15 |
Of course, this year your moving @ a slow pace vs. last year.
