Old 07-22-2007, 01:44 AM   #1
Down south truckin
Down south truckin's Avatar
some stuff that i need to sell (misc)
here is some stuff that i need to sell prices are plus shipping
1 wood grain gauge cluster $35
2 power brake setup off a 72 with front disc brakes $60
3 2wd auto crossmember off a big block th400 truck $40
4 5 lug disc brake setup (rotors,calipers,spindles,upper+lower control arms) SOLD
5 power steering set up includes ps box and small block long water pump style pump and brackets SOLD
i will accept paypal, money orders , cash or checks but checks must clear before i will ship the part please respond in this thread thanks Mike
Down south truckin is offline   Reply With Quote
Old 07-22-2007, 01:54 AM   #2
Down south truckin
Re: some stuff that i need to sell (misc)
here are some more parts that i need to sell prices are plus shipping
6 71-72 2wd front bumper brackets $25
7 72 big block automatic 400 trans shift linkage 2 pieces that are unique $30
8 67-70 automatic steering column th 350 and th400 driver condition needs some tlc SOLD
9 71-72 automatic steering column th350and th400 driver condition needs some tlc also SOLD
10 tail light housings and back-up housings with some of the wiring $30
Old 07-22-2007, 02:07 AM   #3
Down south truckin
here are a couple more pieces prices are plus shipping i will have more pics of more stuff tommorrow because the city code enforcement officer stumbled a
cross my stash
11 ac dash no damage except a temp gauge has been added $75
12 emergency brake assembly $20
13 evaparator core cover have both sides or seperate $50 both $30 each
14 oil filler tube with A/C $ 30
thanks and look back later for more stuff
Mike
Old 07-22-2007, 02:27 AM   #4
DMARCUM123
whats the difference in a big block cross member and a small block
DMARCUM123 is offline   Reply With Quote
Old 07-22-2007, 02:45 AM   #5
Down south truckin
I don't think there is any diffrence but i know that this came off a bb-400 truck thanks Mike
Old 07-22-2007, 07:24 AM   #6
uncle
The big block usually has the 2 clamps bolted to the back like the one in the pic.
uncle is offline   Reply With Quote
Old 07-23-2007, 12:23 AM   #7
Down south truckin
here is some more parts prices are plus shipping
15 blue 4 bar steering wheel very dirty $40
16 center a/c vent bezel is cracked it has the back vent duct+1 of the nuts$10
17 cargo light has some pitting,gasket,lens,wiring and switch $20
18 a pair of coil spring u-bolts and shock plates 1 of the u-bolts has a couple gauges in it from my helper he was going to try to cut the u-bolts with a sawzall $20
19 panhard bar off a 72 1/2 ton lwb $10
20 A/C control good shape with 1 lever broken $10
more to come!!! thanks, Mike
Old 07-23-2007, 12:29 AM   #8
Down south truckin
21 cigar lighter wiring harness SOLD
22 factory speaker with bracket $5
23 ignition switch with GM key SOLD
24 set of factory big block springs out of 1/2 ton lwb big block truck SOLD
thanks Mike
Old 07-23-2007, 02:29 AM   #9
19GMC63
19GMC63's Avatar
A few question about the power steering setup.
What was it out of? And do you know if it was in good working order before removed?
I'm looking at using it to to put power steering on my GMC, and according to some sources, 69 and later boxes work.
thanks
19GMC63 is offline   Reply With Quote
Old 07-23-2007, 08:57 AM   #10
faribran
i would like the ignition switch with key.. and the tranny linkage (pending how unique it is to a 400 only.. will it work with a 350?)
also.. does the power steering box or pump leak? whatz the general condition?
faribran is offline   Reply With Quote
Old 07-24-2007, 12:09 AM   #11
Down south truckin
thanks
19GMC63 the power steering came off a 72 1/2 ton lwb the truck has been sitting for a few years. the previous owner told me he drove the truck daily for a few years, but that was awhile back. thanks Mike
Old 07-24-2007, 12:12 AM   #12
Down south truckin
faribran i have shifter linkage for a 350 if thats what you need I'll get a pic of it tommorrow which pieces do you need? the box does'nt apear to be leaking but it's been sitting for a few years so who knows?
Old 07-24-2007, 03:07 AM   #13
19GMC63
19GMC63's Avatar
any idea on what shipping would be to 37062?
thanks
Old 07-24-2007, 07:58 AM   #14
sdailey
The Few, The Proud
sdailey's Avatar
Mike,
What's the overall condition of the dash? Can I get some more pictures?
Thanks,
Shannon
Shannon
sdailey is offline   Reply With Quote
Old 07-24-2007, 12:11 PM   #15
faribran
Down South,
I need pretty much every part of the linkage from the column shift lever(on firewall) to the pivot to the tranny.....if you have this plz advise how much you are asking plus shipping cost.
thanx
Old 07-24-2007, 09:57 PM   #16
mrdurden
sent pm
'67 2wd LWB Fleetside
'71 4wd LWB Fleetside
mrdurden is offline   Reply With Quote
Old 07-24-2007, 10:48 PM   #17
Down south truckin
Originally Posted by sdailey View Post
Mike,
Thanks,
Shannon
Shannon here are a couple pics that i had on my pc i can get some more tommorrow thanks, Mike
Old 07-24-2007, 10:56 PM   #18
Down south truckin
Down South,
thanx
faribran here is what i got it's missing the u shape piece that bolts to the transmission I'll take $35 plus shipping give me your zip code and I'll get you a shipping price thanks Mike
Old 07-24-2007, 11:12 PM   #19
Down south truckin
thanks
shipping to 37062
usps is $24
ups is $41
fed-ex is $34
thanks Mike
Old 07-24-2007, 11:15 PM   #20
Down south truckin
Originally Posted by mrdurden View Post
sent pm
shipping on the power steering
usps-35
ups-55
fed-ex-45
shipping on the power brake setup
usps-25
ups-55
fed-ex-45
thanks Mike
Old 07-25-2007, 09:15 AM   #21
sdailey
The Few, The Proud
sdailey's Avatar
Mike,
I'm interested in the metal dash, not the instrument cluster.
Shannon
Old 07-25-2007, 09:53 PM   #22
Down south truckin
Mike,
DOH!! my bad the dash is in great shape the only thing altered is the temp. gauge that has been added I'll get some more shots tommorrow thanks Mike
Old 07-26-2007, 10:59 PM   #23
faribran
mike, ill take it pending shipping.....to 36345
ill take the ignition switch with key, also
thanks
Rich
PS i am going out of town in the am... ill check in the morning and do the paypal thing... thanx.
Old 07-26-2007, 11:35 PM   #24
Down south truckin
thanks
Rich
Rich, the usps web site says 9.49 shipping for a total of $49.49 my paypal address is mtbbailey@yahoo.com thanks mike
Old 07-26-2007, 11:43 PM   #25
Down south truckin
Mike,
Here are some more pictures there is no damage other than the 2 holes that were drilled for the gauge the place in the pic where i started trying to split the spot welds and a little surface rust here and there thanks Mike
