Old 07-22-2007, 09:58 AM   #1
bigblock79
67 Chevy Stepside
bigblock79's Avatar
I just score some lowing stuff
i got some 3in drop spindies. and 2 in lowering spring and a flip kit out back going to put them in this week. have any one run 255-70-15 up front and 285-70-15 out back. thanks
1967 Chevy stepside
1976 BIG DOOLEY 454 turbo 400 4:11
bigblock79 is offline   Reply With Quote
Old 07-22-2007, 10:44 AM   #2
piecesparts
Parts and more parts
piecesparts's Avatar
Re: I just score some lowing stuff
The 3" drop spindles and the 2" drop springs may just put you on the ground, hard. You may have to go a little less than that, especially for those tires, the 255/70/15 is a 29.06" tall tire and the 285/70/15 is a 30.71" tall tire. You may not have front fender well clearance for that tall of tire.
piecesparts is offline   Reply With Quote
Old 07-22-2007, 01:04 PM   #3
boatpuller
boatpuller's Avatar
cool.............see ya down here. ..check out a thread by bigblock 73 (jeff).he just went thru some trial and error with 15 inch wheels.his turned out nice.iv'e got 3 inch spindels and 1 nch coils.but 17 inch wheels.so it's different.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 07-22-2007, 02:32 PM   #4
streetstar
streetstar's Avatar
a 245 or 255/60 tire on the front might work better --- that tall of a tire in the back will give it some rake too
streetstar is offline   Reply With Quote
Old 07-22-2007, 02:42 PM   #5
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
Hah, not really - sure the size-designations of the tires will be different, but what matters is the overall diameter of the tire, and those can be had from online tire dealers like Tire Rack. So really you say what tires you have, bigblock79 looks them up for dimensions, finds a 15" tire that is as wide as yers and has the same diameter as yers, we call it a day
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
Old 07-22-2007, 03:52 PM   #6
piecesparts
Try this calculator and it will lay you onto some tire diameters real fast.
http://www.discounttire.com/dtcs/infoTireMath.dos
Old 07-22-2007, 05:03 PM   #7
boatpuller
boatpuller's Avatar
not nessicarily true.while overall diameter is the same.you can run into some lower control arm clearence issue's with 15 inch wheels and drop spindles.i did.some don't though.
