Old 07-22-2007, 08:02 PM   #1
dan42
dan42's Avatar
Window lubrication?
Does this channel need to be lubricated with grease? When I pulled the window out to replace the regulator, the channel had some well worn grease on it, but the rollers on the regulator are nylon. Not sure to grease or not.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 07-22-2007, 08:29 PM   #2
dan42
dan42's Avatar
Re: Window lubrication?
ttt
Philippians 4: 6-7
Old 07-22-2007, 09:26 PM   #3
dan42
dan42's Avatar
bump-
Philippians 4: 6-7
Old 07-22-2007, 09:31 PM   #4
Aarons72s
Grease it. They really should be greased every few years but most, including me, dont do it. I have used chasis grease, lithium grease ( the best choice) and wheel bearing grease. Like I said lithium grease seems to do the best. But most of the time I use whatever I have lying around.
Aarons72s is offline   Reply With Quote
Old 07-22-2007, 09:36 PM   #5
Igotachevyor2
Apache Club
Igotachevyor2's Avatar
white lithium works well
58 CHEVY APACHE I 74 CHEVY C-10 I 78 K-10 donor truck I 89 SONOMA
My Trucks Apache Sitting Idle MySpace
Project Dad's Truck (74 C-10 to K-10 conversion)
Igotachevyor2 is offline   Reply With Quote
Old 07-22-2007, 09:40 PM   #6
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I grease mine when I put them in and if I remember whenever I have the doorpanel off.Seems to make the window easier to roll up and down.If it affects the nylon I've never noticed.I also spray the window run channel with silicone.I do that whenever the window gets a little stiff.Also grease the sissors of the regulator.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
