Old 07-22-2007, 09:34 PM   #1
68 short step
whats wrong with this? (trailing arm ?)
when i was looking at the frame i noticed this on 1 of the trailing arms... it looks like there was something that connects both sides of the arm, but it is all cracked and weathered (corroded?) so is this "ok" to use like this? this truck will be used for hauling. both boats/jetski's and a$$... would trailing arm reinforcement plates be the best option to fix this?? last pic is the oposite side, this one looks good..
68 short step is offline   Reply With Quote
Old 07-22-2007, 09:35 PM   #2
Aarons72s
Re: whats wrong with this? (trailing arm ?)
Pics?
Aarons72s is offline   Reply With Quote
Old 07-22-2007, 09:36 PM   #3
grady5
any pics?
grady5 is offline   Reply With Quote
Old 07-22-2007, 09:48 PM   #4
Aarons72s
I see your pics now. That is the control arm rusting apart. They will require replacement. Mine on the orange and white did that. When they get chronic rust they start mushrooming with layers of rust. Sorry man.
Old 07-22-2007, 10:00 PM   #5
killer71
killer71's Avatar
Wow! good catch don! so now what?
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 07-22-2007, 10:08 PM   #6
Big White GMC
Big White GMC's Avatar
What I'd Do Is Remove The Arms, Sandblast Them, And Then Get A Set Of The Reinforcement Plates From Early Classic Enterprises. The Part # Is 902-6072TAR. That Will Help Your Situation Greatly. Good Luck !!!!
Big White GMC is offline   Reply With Quote
Old 07-22-2007, 10:14 PM   #7
72CSTC5
72CSTC5's Avatar
Get a c-clamp and butt it back together and put some stitch welds in between the two halves about every six inches or so. Less expensive than the plates and will do the same job.
72CSTC5 is offline   Reply With Quote
Old 07-22-2007, 10:18 PM   #8
killer71
killer71's Avatar
but how long will that last? Remember I'm gonna have killer 4 ever!
R.I.P.
Killer 71
10/26/07
Old 07-22-2007, 10:20 PM   #9
72CSTC5
72CSTC5's Avatar
It will last, just have them sand blasted and make the welds. What happened is the plug weld in that one spot broke loose. Replace that weld as well. Let me see if I can find some pics of my trailing arms where I welded them up.
Old 07-22-2007, 11:39 PM   #10
Richard H.
Spanked once
Richard H.'s Avatar
Just welded mine today and on top of that it looks like you need new bushings also.
Richard H. is offline   Reply With Quote
Old 07-23-2007, 12:47 AM   #11
SCOTI
SCOTI's Avatar
I agree.
Clamp it back together & lay some 1" beads every six inches the length of the arm. If you want to reinforce them, some .125" or .187" 'drop' plate from the local steel yard (or scrap pile) will get the job done easily.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-23-2007, 01:14 AM   #12
GREASEMONKEY72
GREASEMONKEY72's Avatar
Originally Posted by SCOTI View Post
I agree.
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 07-23-2007, 03:27 AM   #13
drivethechevy
drivethechevy's Avatar
my 68 has the same weld patch described on the control arms
i didnt do them myself but i know from the guy i bought it from who did and i have to so if a person takes the time to fix it right it lasts a long time
the rewelding was done in 77 and when i got the truck for parts in march they were still perfect thanks to the great job the welder did
so make shure there sand blasted and cleaned up real good before u weld and then after the weld be shure to repaint and seal it all really well in the long run its worth the effort causeas original steel is gettin alot harder to find in good condition for a decent price savin what u got is the best idea
Trial and Error, its expensive but its a mistake i most likely wont make again
1971 chevy k10 custom deluxe
http://67-72chevytrucks.com/vboard/s...d.php?t=341257
1968 chevy k/10 fleet
http://67-72chevytrucks.com/vboard/s...d.php?t=334731
1948 desoto custom coupe fluid drive(family heirloom)
drivethechevy is offline   Reply With Quote
Old 07-23-2007, 04:23 AM   #14
krue
Designated A-hole!
krue's Avatar
A good patch and you're gonna be alright, it's not like a truck that's seen a lot of salt and you would expect a lot of serious rust.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 07-23-2007, 04:35 AM   #15
jc
jc's Avatar
good used ones are cheap.
if your doing a decent build why do a repair that will stick out like a sore thumb.
if its a fire wood hauler go ahead and weld it.
thats just my opinion , i like to see parts in as left the dealership condition and not modified.
2004 Silverado 2500HD Crewcab 4x4
2000 TOYOTA 4RUNNER
1971 CHEYENNE LWB (THE LOVE SHACK)
1967 c-10 lwb (THE FARMERS DAUGHTER)
jc is offline   Reply With Quote
Old 07-23-2007, 09:03 AM   #16
mike nutt
69fatmotor
mike nutt's Avatar
i welded mine up solid , djracer's drag truck has stock trailing arms that are welded up solid without a problem and it totes the front tires. here's a picture of mine.
mike nutt is offline   Reply With Quote
Old 07-23-2007, 11:49 AM   #17
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
I agree with all the above to have them blasted and be sure all the junk in between the two halves is cleaned out real good, then clamp them together and run some stitches every so often. I welded some 1/8" strap onto mine, but I did it more for looks that anything else.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 07-23-2007, 01:14 PM   #18
mvfd70
mvfd70's Avatar
Mine were like that too. Some of the welds/rivets were broken so I drilled them out with a drill press and took the arms apart, cleaned out all the scale and rust, and they are at the welder right now getting the rust holes patched up. I figure some 1/2 inch grade 8 bolts will hold them together nicely.
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
Old 07-23-2007, 03:16 PM   #19
LockDoc
The Older Generation
LockDoc's Avatar
I took mine apart also. I didn't really want all of the rust and packed in dirt in between mine and I couldn't get it all out. Not really that hard to do and it makes you feel great when you get it all done....
LockDoc
Leon
Old 07-23-2007, 03:45 PM   #20
Metmanice
Metmanice's Avatar
Don't forget the other alternative.
Early Classic sells a pair of boxed trailing arms for $459 with spring cup, new bushings and u-bolts included.
I have a pair and they are worth the money.
'67 C10 SWB Frame off (and smiling)
Metmanice is offline   Reply With Quote
Old 07-23-2007, 03:49 PM   #21
killer71
killer71's Avatar
any pictures possibly?
R.I.P.
Killer 71
10/26/07
Old 07-23-2007, 03:52 PM   #22
Metmanice
Metmanice's Avatar
Their site has them in red, but they come powdercoated black.
I have more pictures at home of mine sitting in the frame with air bags. If you want to see them let me know and I can upload them tonight.
Old 07-23-2007, 03:58 PM   #23
killer71
killer71's Avatar
yea i saw those red ones and was hoping you could get them in black...always wanna see the picts dude...if you can swing it.
R.I.P.
Killer 71
10/26/07
Old 07-23-2007, 03:59 PM   #24
Metmanice
Metmanice's Avatar
No problem. I will post tonight.
The great thing about these is that even the u-bolt hole are boxed. No more rust problem ever.
Old 07-23-2007, 06:08 PM   #25
Richard H.
Spanked once
Richard H.'s Avatar
I went and looked at mine again and my new bushings and something is up with your first picture like someone hacked on the collar of the bushing or some how your bracket got bent. Compare it to the other side in next pictures. The arm still needs to be clamped and welded but some how that frame bracket looks suspect IMO . There is no rubber on the out side of the arm and it appears to be digging into the bracket?
