Old 07-22-2007, 10:57 PM   #1
cameeks
Long Fleet Club
cameeks's Avatar
Front shoe replacement
I was wondering how much time and what is all involved in changing the front brake shoes (drum). I have worked on almost all kinds of brake systems ( and probably do this by looking at the setup) but I have never done a front drum befor and want to do it befor work tomorrow. I searched Krue's FAQ section but I didn't see anything. HELP
Chris Meeks
'69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling.
Truck is now finished to the new owners design and running around.
I was shown some pictures of the finished product. At least it survived the junk yard.
FAQ Index by Krue Site Vendors Subscribe Here Forum Rules
cameeks is offline   Reply With Quote
Old 07-22-2007, 11:09 PM   #2
'68 longbed
'68 longbed's Avatar
Re: Front shoe replacement
all of 'em are pretty much the same. just do one side at a time so you can reference the spring location etc.
"spiiiider pig, spiiiiider pig, does whatever spiiiider pig does. "
'68 longbed is offline   Reply With Quote
Old 07-22-2007, 11:09 PM   #3
longhorn70gmc
longhorn70gmc's Avatar
Its real easy. Small shoe to the front and big shoe to the back. I do mine in halves. I take the big shoe off first and reinstall the new one putting it all back on with the other stuff. Then I do the little shoe and am done in 15 to twenty if not faster. If your drum doesn't want to come off then you may have to loosen the star so it backs the breaks off the drum. Good luck, I just did the whole truck in less then an hour.
Billy
1970 GMC Sierra Grande 402/TH400
(Longhorn)14 years and counting rebuild!
1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches
1970 Ford F250 Ranger 390 BB
2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires
Hub Cap Freak!
I need another truck like I need another hole in the head!
I'M IN THE MARKET...AS IT WERE!
Last edited by longhorn70gmc; 07-22-2007 at 11:11 PM. Reason: Add a couple words to sound better.
longhorn70gmc is offline   Reply With Quote
Old 07-22-2007, 11:17 PM   #4
cameeks
Long Fleet Club
cameeks's Avatar
[QUOTE=longhorn70gmc;2274950]If your drum doesn't want to come off then you may have to loosen the star so it backs the breaks off the drum. QUOTE]
Chris Meeks
Old 07-22-2007, 11:19 PM   #5
cameeks
Long Fleet Club
cameeks's Avatar
Does the front drums come off like a front rotor on the 80's trucks and cars or do the wheel bearings stay sealed with the drum off?
Chris Meeks
Old 07-22-2007, 11:20 PM   #6
'68 longbed
[QUOTE=cameeks;2274960]
use a "bfh" a big friggin' hammer.
tap moderatly hard all the way around the drum and it will almost always pop loose.
Old 07-22-2007, 11:42 PM   #7
70C10Toejam
Hellasick
70C10Toejam's Avatar
The front drums come off just like the disks do, remove the castle nut and pull. If the drum hangs on the brake shoes, you will need to knock out the "knockout" in the drum, a small oval near the outer edge of the drum. when the hole is at the bottom, you will see a "star" wheel, that is the adjuster. I don't remember if you turn the adjuster up or down to back the shoes off, it is fairly obvious, easier to turn when NOT pushing against the return springs. After thinking about it...I think you want to turn it down, On the rears, the auto adjuster pushes down FROM THE INSIDE OF THE STAR, which would be up from your point of view. With the rears, you need to push against the adjuster to get it away from the star, I don't believe the fronts are self-adjusting, so it should not be an issue.
Sorry, could not find a pic for you.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes)
This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do.
RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!!
BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys
70C10Toejam is offline   Reply With Quote
Old 07-22-2007, 11:44 PM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Do you have brake spring pliers? They make the job a lot easier...
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 07-22-2007, 11:44 PM   #9
cameeks
Long Fleet Club
cameeks's Avatar
ok so have some grease available then?
Chris Meeks
Old 07-22-2007, 11:44 PM   #10
cameeks
Long Fleet Club
cameeks's Avatar
got those without the part on the handle
Chris Meeks
Old 07-22-2007, 11:48 PM   #11
70C10Toejam
Hellasick
I got a set of those...might as well use some broken needle-nose and a razor blade.
but yes...some disk-brake grease is good.
Old 07-24-2007, 03:40 AM   #12
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
get new seals for the bearings, and clean/repack the inner and outter bearings. inspect them real close too. It's very easy, the parts are all cheap, and not doing it can be disaterouse. I almost lost a wheel due to bearing falure on a back woods tx two lane doing speed limit X 2.
Even at the speed limit, the results woulda beel just as bad.
Old 07-24-2007, 03:46 AM   #13
krue
Designated A-hole!
krue's Avatar
Take a lot of pictures and write a FAQ for us.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 07-24-2007, 08:43 AM   #14
Truckstr
Truckstr's Avatar
Exclamation Re: Front shoe replacement
I can't speak for the 1969's like yours, BUT when I went to inspect the front brake shoes on my '66, the drums were still riveted to the hub. In order to remove the drums - and avoid cutting off the rivets, I had to take off the entire assembly via the center bearing castle nut. Ya can't get more original than that! If that hadn't been the case, just removing the wheel (and maybe backing off the adjusting "star" - access hole in the backing plate) would have allowed the drums to be removed.
BTW, yes the shoes needed to be replaced. They were paper thin. BUT, the drums were as smooth as glass, didn't have a ridge worn into them that would hold the shoes inside the drum and no hot spots, so they didn't have to be turned. I was pretty surprised. Needless to say, I'll do my best to keep from ever having to cut those rivets.
Jeff
'67 short Fleet; my ongoing project.
'66 long Fleet; my original "baby."
Live life or bust trying.
Truckstr is offline   Reply With Quote
Old 07-24-2007, 01:11 PM   #15
cameeks
Long Fleet Club
cameeks's Avatar
I can write one up but can use some info like how the castle nut is supposed to be installed. I have been doing it for years and can do it by feel but cant explain the technical part of it. It is like one of those I can do it but can't explain it things
Chris Meeks
Old 07-24-2007, 01:57 PM   #16
Mt Man Chad
Mt Man Chad's Avatar
They say a picture is a thousand words. I took before I did mine two weeks ago so I would never forget.
Driver side shown = Passenger side is just opposide of what is shown!
Just make sure you don’t swap the lower screw adjuster one side is LH thread and the other is RH thread. Otherwise your breaks will not adjust correctly!
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
Old 07-24-2007, 02:48 PM   #17
nplocoman
never finish start another
nplocoman's Avatar
I would also suggest new wheel cylinders or at least hone and kit the old ones! Not moch more money. The last time I did this I also put on new drums. The old ones did not turn true.
nplocoman is offline   Reply With Quote
Old 07-24-2007, 03:54 PM   #18
Longhorn Man
New cylinders aren't a bad idea... but I would avoid the new drums unless you need them. I found they warp REAL easy, and in all reality, it took a few hrs of labor to make a hole in them to adjust the brakes. I was very disapointed in the lack of correctness on the replacement drums. (refering to my last truck, 1/2 ton SWB GMC, not my one ton)
Old 07-24-2007, 04:58 PM   #19
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I usually clean the threads on the adjuster with a wire brush and then anti sieze them.That way they tend to keep auto adjusting better.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 07-24-2007, 06:39 PM   #20
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Doing the brakes, front or rear, is really easy. Just when doing the front, be sure the adjusters are working, and you get the wheel-bearings set up right. I don't know what others have found, but when I got those things right, my left/right pull completely disapeared. I can hit the brakes hard (4 wheel drum manual) and I brake nice and straight and stop fast!
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 07-24-2007, 07:14 PM   #21
nplocoman
nplocoman's Avatar
Hey longhornman are you talking about the drums or the backing plate? You have me a bit confused? How do you make a hole in the drum for adjusting?
Old 07-25-2007, 12:28 AM   #22
longhorn70gmc
[QUOTE=Mt Man Chad;2277145]They say a picture is a thousand words. I took before I did mine two weeks ago so I would never forget.
Thanks for posting the picture for him. I still struggle with posting those.
Billy
Hub Cap Freak!
Old 07-25-2007, 01:56 AM   #23
cameeks
Long Fleet Club
cameeks's Avatar
I got it done but with 15 min left for work so the pics stop after the drum is taken off. The po got some nuts and bolts and bolted the drum to the hub oh well. I'm just trying to get it to last until I do my 4 wheel disk swap. I'm flushing the system in the morning.
Chris Meeks
Old 07-25-2007, 02:02 AM   #24
cell
Active Member
cell's Avatar
I just finished doing this yesterday, and will be posting pictures soon.
cell is offline   Reply With Quote
