Old 07-23-2007, 04:29 AM   #1
fercho71
fercho71's Avatar
1969 chevy 3/4 ton rear end
hey guys a question for all of you does a 1968 camaro rear end differential would fit on my 1966 chevy 3/4 ton truck is there any special adaptation for it?
1966 chevy c-20 truck " La Chata " under construccion
fercho71 is offline   Reply With Quote
Old 07-24-2007, 12:22 AM   #2
fercho71
fercho71's Avatar
Re: 1969 chevy 3/4 ton rear end
anyone any comments please help
Old 07-24-2007, 12:29 AM   #3
1969k10stepside
The camaro would be a 5 lug and you want to put it in a 3/4 ton (8 lug)? I dont know your truck but the camaro has leaf springs so if your truck has coils you would have to modify it to work in your truck.
1969k10stepside is offline   Reply With Quote
Old 07-24-2007, 12:56 AM   #4
fercho71
fercho71's Avatar
I spoke to the seller today and he told me that it is coil also, i don't plan to carry heavy things on the truck, i want it for my daily driver my question its do you think it will fit?.
there both are coil
Abouth 3 months (before i know the differential was damage) i ask to a truck owner how to change from 8 lug to 5 lug wheels and he suggested me to install a 1969 camaro rear end, know that i finally found it my question its.
Do i have to make any special modification?
does the weight of the truck would affect the performance?
I also planed to lowered by cutting on the coils, i really appreciate if any one cant helP with this questions?
Thank you for taking the time to review my thread
Fer.
Old 07-24-2007, 01:04 AM   #5
wild one
Registered.........
wild one's Avatar
If your truck has rear coil springs instead of leaf springs, I would look for a 1971 -1972 chevy C10 rear end. It would be a direct bolt in (assuming that the 1/2 ton and the 3/4 ton rear coil setup is the same) and has the five lug axles. Also, the camaro rearend will have a 5 on 4 3/4" bolt pattern, not the 5 on 5" that these trucks had from 1971 to 1987.
1966 C10 panel-400 small block/TH 350 combo
Nothing is fool proof to a talented fool!
Popcorn:
Pops at exactly 444 degreese
Expands to 44 times it's original size
Has a 4 year shelf life
wild one is offline   Reply With Quote
Old 07-24-2007, 01:17 AM   #6
fercho71
fercho71's Avatar
thanks wild one i would look for one like that !!!!!!!
