Roof: Bad. Sky: Good.
![]() Join Date: Jul 2007
Drums, Steering & Lowering
This is Olesenna's Mechanic.
I'm working with a 1972 Blazer K/5 4wd w. a 350. First of all, 6 lug rear drums are hard to find, I found one site (manestruckparts.com) that sells them for $79.95. Is that the best price out there? Can I do better? Any recources? This truck came to us equipped with Skyjacker 2.5" all spring lift with Pro-Comp shocks (oversize) (no blocks in rear, new springs used from Skyjacker). Is there any way to lower it without replacing the items above? The steering has a new Crossover steering conversion with a new steering box, Pitman arm and crossover arm using a custom draglink. *EDITED BY MODERATOR* Last edited by HuggerCST; 07-23-2007 at 01:39 PM. Reason: WTB- Non subscriber |
Re: Drums, Steering & Lowering
Sorry, but you have to be a subscriber to post a "want to buy". Click the link in my signature to subscribe.
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
Greetings, fellow Blazer (& Jimmy) enthusiasts. I'm a newbie on the posting side, but I've been lurking around for several months. Terrific site! Good info, lots of entertaining characters and an impressive gathering of machinery.
Please check out the message posted earlier today. It originated from the shop currently helping me tweak my recently purchased '72 4WD K5. This is my second dance with a '72 Blazer. The first one, which I modified as a DD back in the late 1980s-early 90s, was a mildly customized 2WD model, Hugger orange with black interior, slightly lowered, chrome 15-inch American Mag style wheels, crate 350/Edelbrock carb & manifold/Hooker headers, turbo 350 tranny with B&M drag-style floor shifter, custom rollbar, Recaro-type sport buckets and BestTop convertible top. It was my dream ride until an inebriated bonehead smacked it sideways and the insurance barely covered the towing charge. In any case, I managed to retain the seats, which will be installed in my new Blazer. Speaking of which... Here we are, a decade and change later, and I finally got my hands on another 1st gen Blazer. This time 4WD, ochre ext/black int, crate 350 w/ goodies, 350T, Skyjacker raised 2.5", 32" BFG all terrains. It's in decent running order with a few issues need attention. In our original message, my mechanic described the issues (drums, steering & lowering), but in so doing asked about purchasing some equipment, which is why moderator HuggerST understandably stepped in. We're interested in getting my Blazer in the best shape possible within a limited budget, which means we're always looking for the best deals possible. More importantly, though, this is the first time we've tackled a 4WD project of this type, so we have much to learn. (To clarify the steering problem, symptoms include a soft, wandering looseness around the center and inability to hold a true line on the road, esp. with the big BFGs, which will soon be replaced by more streetable meats.) Please take a few minutes to ponder our concerns. Your interest and input will be greatly appreciated. Thanks in advance for your replies. PS Since I know how much everyone enjoys visual aids, we'll post a few pics of the Blaze ASAP! |
Post Whore
![]() Join Date: Feb 2000
Sounds like your mechanic needs to inspect the front end components to see what is worn. Tie rods ends are a likely culprit and easily replaced. Your steering box could be worn and causing the problem. I'd get the new tires on and have him inspect the frontend and go from there.
I'll let others chime in about your rear drum replacement options. I'm surprised your local Napa/Autozone/O'Reilly's can't source the drums. Oh, welcome to the board! It holds a wealth of information.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
If this turns out like it's supposed to, you can take a look at a few pics of my recently acquired '72 Blazer. If not, I'll keep trying until it works.
Attachment 285494 Attachment 285495 Attachment 285496 Attachment 285498 Meanwhile, we found 6 lug rear drums for $60 apiece. Still seeking tips on steering and lowering issues previously described. Hope someone can help. Thanks in advance!
OleSenna |
I had similar issues and it was a broken spring pin to hold the axel in place. New springs fixed this.
Post Whore
To lower it, you really need to get replacement springs. Someone might have a used set that wouldn't be worth much. Other than that, you will need to buy new. Is it really worth your effort to drop it 2.5"? That isn't very much and your gonna end up doing a fair amount of work and replace good parts to barely change the height.
Thanks for the`feedback. It's not that we've settled on dropping the body 2.5". That's just the height of the Skyjacker lift job as indicated by the previous owner.
I'm looking to get the body down to "normal" street level, whatever that might end up being. Not slammed, just providing more convenient access to a vehicle that will be used for a daily driver. Does that change your suggestion? In this case, I definitely agree that springs are going to be a part of any lowering project. Anybody got a lead on a pair?
OleSenna |
urban fourwheelin
Don't just cheap out and buy the least expensive drums you can find. I found them at 49.00 a piece when I did my rear brakes, They were junk and didn't fit well. I ended up returning them.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage. |
Led Sled! Discs R 4 ME!
![]() Join Date: Jan 2001
For a steering gear contact Wes at Classic Heartbeat.
He carries Red head remanufactured gears in variable or quick ratio. I put one of these in my highlander and it awsome! http://www.classicheartbeat.com/ |
