07-23-2007, 01:05 PM | #1 |
Modifed Inner Fenders - Let's See Em
Front and rear. Whatcha got? Post yours and/or others' from your hard-drive if you've got em
07-23-2007, 02:57 PM | #2 |
A guy with a truck
Re: Modifed Inner Fenders - Let's See Em
Raguemoe's
Green69's Kyle4381's meangreen70's camaro_thunder's That should be enough to get the gears grindin' a little...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 07-23-2007 at 03:12 PM. |
07-24-2007, 01:51 AM | #3 |
Some of those look pretty sweet. Thanks Gringo. I'm thinking about just modifying the outer ~3" or so of the fronts so it won't be visible under the hood. Anyone done something like this? I'm wondering if it's worth the effort and how much it'll tuck.
Also I'm going to have to move the rear tubs up at least 2.5" so I'm looking for some creative ways of doing so. |
07-24-2007, 02:31 AM | #4 |
A guy with a truck
I was kinda thinking this too. Just take out the part between the fender lip and where it meets the underside of the fender. This is really the limiting factor if you're not trying to lay out. Should give you another inch or two of drop. Only thing is, now your tires are throwing debris inside your fenders...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
07-24-2007, 12:34 PM | #5 |
Definately gotta replace that section with something up higher to prevent trashing the fender lips.
07-24-2007, 08:24 PM | #6 |
A guy with a truck
Maybe something like what n2billet did on 'Lucy'
07-29-2007, 12:17 PM | #7 |
Under construction.
