Old 07-23-2007, 08:44 PM   #1
RedZ71
Junior Member
RedZ71's Avatar
ok, silly question...
uh.. how do you remove the wiper arms?
(i dont have a sawzall, so ill be forced to use wrenches and remove them properly!)
Jonathan
2001 ECSB Silverado Z71
1971 LB C10 Custom
www.z71silverado.com
RedZ71 is offline   Reply With Quote
Old 07-23-2007, 09:16 PM   #2
70C10Toejam
Hellasick
70C10Toejam's Avatar
Re: ok, silly question...
how bout a Fjord wrench???
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes)
This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do.
RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!!
BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys
70C10Toejam is offline   Reply With Quote
Old 07-23-2007, 09:16 PM   #3
68gmsee
Active Member
68gmsee's Avatar
If you're talking of just the arms, I just removed mine. I placed a cloth on the arm where it connects at the cowl and used, believe it or not, a claw hammer to pry it up. I made sure the cloth was draped over the hammer and "gently" pried it off. Lift the spring loaded arm up at the same time if it has a spring loaded lock on it and gently rock it as you pry to loosen it if it is stuck.
Mine came up fairly easy, but I've removed them twice in the last year or so.
Good luck...
68gmsee is offline   Reply With Quote
Old 07-23-2007, 09:17 PM   #4
woodrow59
OzarkHillbilly in Atlanta
try this http://67-72chevytrucks.com/vboard/s...t=remove+wiper
72 custom/10 LWB
68 Longhorn C20 Custom Camper (sold)
woodrow59 is offline   Reply With Quote
Old 07-23-2007, 10:47 PM   #5
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
^+1 for the tool mentioned in the link. I got mine at Napa.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 07-23-2007, 11:08 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
I use my brake adjuster tool with a rag wrapped around it. Works pretty good.
LockDoc
Leon
Old 07-23-2007, 11:12 PM   #7
drivethechevy
drivethechevy's Avatar
al of that works just fine
but wrenches and screwdrivers work just as well
Trial and Error, its expensive but its a mistake i most likely wont make again
1971 chevy k10 custom deluxe
http://67-72chevytrucks.com/vboard/s...d.php?t=341257
1968 chevy k/10 fleet
http://67-72chevytrucks.com/vboard/s...d.php?t=334731
1948 desoto custom coupe fluid drive(family heirloom)
drivethechevy is offline   Reply With Quote
Old 07-23-2007, 11:37 PM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I have a tool like this one... works pretty well.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 07-25-2007, 11:34 PM   #9
RedZ71
Junior Member
RedZ71's Avatar
well, the wiper blades ended up comming right off without any real argument. thanks for the advice yall!
here is where im sitting now:
my wiring is a ghastly sight, im thinking about pushing that project up since i have the front torn apart (for ease of access).
Jonathan
1971 LB C10 Custom
