07-23-2007, 09:31 PM | #1 |
dash pads
two questions
Having a hard time finding a white dash pad or pad cover pure white not off white I know it was not factory. second, has anyone used that top dash cover the LMC sells, covers the metal top pad of dash? (not sure if anyone else sells it.)
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
07-23-2007, 09:37 PM | #2 |
Re: dash pads
the previous owner of my 68 put one of those covers on .....I don't know if it's typical but it clearly had a thin spot in it and the sun made it "bubble" as though someone put a lighter under it in that spot.
i'd say if you get one make sure it appears to be uniform in it's molding.
"spiiiider pig, spiiiiider pig, does whatever spiiiider pig does. " |
07-23-2007, 09:40 PM | #3 |
67-72 Addict!
Re: dash pads
I like the dash caps!. They work well.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
