Old 07-23-2007, 10:20 PM   #1
drivethechevy
drivethechevy's Avatar
a bit of inconveinioce to go original
im int the process of restoring a 69 lwb and the cab that came asembled on the truck was rusted beyond all help
in search of a new cab i found one but the dash had been cut out for a cd player and i want the original radio in the dash
so to find a solurion for this problem worked it out on the rusted cab
there r only about 30 spot welds across the windsheild ledge so i drilled them all out and out came the dash
now i got a cab with dash still spoted in and the dash i want in
whati would like to do is not have to mess with the windsheild ledge on this new cab and i cant really think of a good way to weld or bolt in the new dash
any sudgestions?
Trial and Error, its expensive but its a mistake i most likely wont make again
1971 chevy k10 custom deluxe
http://67-72chevytrucks.com/vboard/s...d.php?t=341257
1968 chevy k/10 fleet
http://67-72chevytrucks.com/vboard/s...d.php?t=334731
1948 desoto custom coupe fluid drive(family heirloom)
drivethechevy is offline   Reply With Quote
Old 07-23-2007, 10:29 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: a bit of inconveinioce to go original
You can cut it across where the dash pad bolts on, tack weld the good part on to it and you are good to go.....
LockDoc
Leon
Old 07-23-2007, 10:32 PM   #3
Green Machine
Green Machine's Avatar
A good place to cut the dash is in between the slots under the dash pad. The welds won't have to be perfect under the dash pad.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 07-23-2007, 10:35 PM   #4
Green Machine
Doc - ya beat me to it I gotta type faster.
Old 07-23-2007, 10:59 PM   #5
drivethechevy
thanks much
i never even thought of that
now i got a task to prep for tomorow
