07-23-2007, 10:21 PM | #1 |
Keep Your Nose Clean
Stock or aftermarket A/C?
I have a 72 Custom Deluxe with an A/C cab, but no A/C. Would it be more cost effective to have the "original" set up put back in the truck or an aftermarket like Vintage Air? Are their other factors I should consider in this decision making process? Thanks ahead of time for any imput you provide.
07-23-2007, 10:23 PM | #2 |
Re: Stock or aftermarket A/C?
hey great topic im subscribing to this one
07-23-2007, 10:43 PM | #3 |
Im curious about this too. My 67 custom doesnt have air or the vents tho. Would a donor truck be feasable....or a new system.
Waiting for anyones stories..... |
07-23-2007, 11:09 PM | #4 |
Chief Honcho In Charge
The vintage air is a lot more compact. Hoever I remember reading that you want the kind of vintage air with the stock/original controls.
Reason is that someone said it was all air or all heat with very little temperature control..like no warm. Not sure if this is true...but I am subscribed now so I will watch. I have the exact same Q.,..My A/C is missing the compressor...did not know if I wanted to simply replace the compressor or go with an aftermarket model. I do like the cleaner firewall look.
1992 1500 4x4 Shortbed 1984 Ford F250 Supercab Longbed 6.9L Diesel 1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C 1971 VW SuperBeetle 1960 Wife 1984 Son 1986 Son 1989 Son Previous Trucks 1967 C10 SWB (1980-1981) 1971 C10 LWB (1998-2004) |
07-23-2007, 11:22 PM | #5 | |
That is interesting. I know vintage requires an existing heater setup, but all trucks at least came with that, right? Thats how the temp control would work for the air also, i think. Id have to cut some round vents in my dash...cuz mines a virgin for the air baby.. |
07-23-2007, 11:36 PM | #6 |
I would pick factory over add on anyday. Even if the after market works better, a correctly done factory system works very well and in the end the truck will be much more desirable. There is just no comparison. JMO
72 Cheyenne Super 80 Silverado Blazer 2wd Last edited by sameyrasmea72; 07-23-2007 at 11:37 PM. |
07-24-2007, 03:18 AM | #7 |
70+ ( Old Skool Club )
I do agree, there is nothing like factory for stuff like A/C etc. !!
I have a question about factory air dashes. I notice on the factory air dashes that the A/C vents on the sides of the dash have an inch or more of metal or plastic on them that the vent part is in.. My question is, is that piece metal or plastic and is it part of the air dash. Hope I explained myself properly. I guess want I want to know is if I add air to my truck I want it to look as factory as possible and if the part I'm talking about is a metal extension of the dash or part of the vent that just sticks out. If its part of the dash then I'd have to find an A/C dash to keep my truck factory looking.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 Last edited by Already Gone; 07-24-2007 at 03:19 AM. |
07-24-2007, 08:04 AM | #8 |
I'd pick stock. Especially if you already have an AC cab.
I'd also adjust your factory POA to work with R134a and recharge the system with that. Follow this link to adjust your POA:http://www.autoacforum.com/messagevi...AR_MSGDBTABLE= Get all new o-rings. Flush the old system. Get a new receiver/dryer. Pull a vacuum. Fill it up with R134a.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
07-24-2007, 08:43 AM | #9 |
the main problem with the factory air is the amt of power it takes to run them// yes they work very well and cool nice but for the 2-3mpg it costs to run if i had a driver i'd go for the modern effiency of the aftermarket if you're looking for a correct trailer queen resto do the stock system
07-24-2007, 09:00 AM | #10 | |
Unless you have another truck to look at, it may be difficult to install a used system, plus, who know if it even works? You may have leaks or have to replace expensive parts. A vintage air set up will set you back about $1,150 with shipping and probably another $100-$150 for the belts and system charge. BUT you will have all the instructions and can use your factory air vents in the cab and the factory A/C controls! A must: You should have at least a 4 core radiator and a good clutch fan in order to keep the engine cool on hot days. I have a 3 core radiator and 7 blade clutch fan and it's letting the truck get up to 200-205 in traffic, which to me is OK, but not great, so I'll be adding electric fans when $$$ permits (probably another $2-300.) My truck is also an automatic, which makes it worse, if your truck is a manual I'd think a 3 core radiator and clutch fan would be ok.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
07-24-2007, 05:03 PM | #11 |
My truck had factory air and it worked fine, but an aftermarket setup really cleans up the engine compartment. It's pretty hard to "dress up" a factory AC setup.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread |
07-24-2007, 05:42 PM | #12 |
I had a non-air cab to start with and wanted the factory "look".
I bought part of the kit offered from oldairproducts.com. It included the evap/heater core assy,wiring harnesses ,and duct hoses that will replace all of the original heater parts. The finished look is very clean. I used original duct vents/ac balls and cut the holes in the dash very carefully. the compressor is a A-6 long style w/custom fit hoses using all the original alum. end fittings. I had them put service ports for r-12 and 134-a freon so if the r-12 gets impossible to find later down the road I can switch easily. If i remember correctly I did the install in a weekend w/a case of beer....and it still works like a champ 6 years later
70swb 42k original body w/454 on steroids transplanted. 400T/373:1 1997 pickle fork V-drive blown 502ci twin 750dbl pumpers |
07-24-2007, 10:29 PM | #13 |
MisterE72...I am partial to factory ac, If your are trying to keep the stock appearance and if you sell your truck some day a factory set up will normally bring more money then that of an aftermarket set up. It all comes down to what you want and your goal. I am going to rebuild my factory air after I get the engine (402BB) rebuilt this fall/winter. JMO
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
07-24-2007, 11:26 PM | #14 |
I've got a non a/c truck and I really dont want to cut into the dash. I've got a factory A/C dash but I don't know if i want to do the work putting it in. So i've THOUGHT about going with something like this http://www.nostalgicairparts.com/getproduct.php?pid=351
Maybe not that one exactly but we'll see.
1978 Chevrolet Silverado 3/4 ton 400 small block. 2000 F-250 Powerstroke 2002 GMC Yukon Denali XL |
07-24-2007, 11:36 PM | #15 |
I understand having A/C takes uses up power. Does one system take less "horsepower" to operate that the other?
07-26-2007, 02:22 PM | #16 |
I would definitely prefer the factory set up as well if I had a truck that came with factory A/C. Using a new Sanden compressor with all the other factory components is an idea too, it is smaller and looks better, but I don't know about performance-wise.
Also, if you go with the aftermarket unit that is built to be out of the way under the glove box (to look factory), you HAVE to remove the factory heat and use their heat due to space constraints. I didn't like that since I have a factory heat only cab with a new heater core that works fine, and I just wanted to bolt up A/C, and not have to remove the heater box and mess with closing up the firewall etc... Just something to keep in mind. I don't know about all the makers, but Old Air and Hot Rod air said this to me. I ended up with a "knee knocker" and factory heat. I like the one you located mvfd70, wish I had found that before I got this! The one I have is like that but miniature as has to be mounted in the middle. Here's a pic of mine, and also a pic of a friend of ours that has one similar to the one you were looking at, that one gets in the way ALOT less, I might buy the new evaporator like that later on... With a unit like this you get to keep all your factory heat which is cool if you want to run a heated defroster for your windshield and also blow cold A/C because it is hot, you can't do that with a combined system.
_______________ Thomas '78 Silverado '74 Monte Carlo '47 Teardrop Trailer East Texas Classics Local Club |
07-26-2007, 03:23 PM | #17 |
the modern systems require far less power to run therefor you dont have the substantial penelty in MPG that occurs with the old factory systems
07-26-2007, 03:50 PM | #18 |
I was consistently getting 13/15 with my truck (city/hwy) before vintage air. I finally got my dash back in and can post back in a month or so to see if my avg. has gone down or not.
07-26-2007, 04:54 PM | #19 |
I have a vintage air system in my camaro, I think the truck system is similar. The vintage air setup works ok, but I do not like that it always uses recirculated air, it is also considerably noiser than a stock type system because the fan is right under the dash instead of outside on the firewall. If I did it again, I would track down factory parts.
When I redo my truck air, I am going to use a new sanden compressor, and the rest of the factory system with an adjusted POA valve for 134 |
07-26-2007, 05:23 PM | #20 |
i found vintage air cheaper because with my AC 72, i needed new everything, and vintage air offered that for less. i reused my controls, but everything else is new. i ripped an o ring today trying to tighten my fittings to get the compressor vacuumed so i can't say much about the temp control, the heater however works good. the rest of the system installed ok, probably as easy as original would of been.
one downfall, the vintage air kit cuts the inside of your glovebox in half. so you can't store a whole lot of crap in there anymore. Last edited by matthufham; 07-26-2007 at 05:26 PM. |
07-26-2007, 05:28 PM | #21 | |
I'll put in my vote for the aftermarket system. I like the adjustable thermostat on the evaporator on the Old Air setup.
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus! Last edited by Zonaman; 07-27-2007 at 12:47 PM. Reason: more info |
