Old 07-24-2007, 07:45 AM   #1
65stepside
65stepside's Avatar
73-87 Crossmember Swap ????s
So I know a few threads have talked about the 73-87 swap. And it seems like it is pretty simple....But i have a few questions that maybe you guys could help me out with!!
I have a 1960 with the torsion bars and am thinking about changing to the 73-87 crossmember.
Do the 73-87's have 6 lug 2wd front ends?? All i've seen is the 5 lug setup. I already have my 6 lug rims that i want for my truck, or would i need to get new rotors with the 6 lug setup?
How does the power steering addition to the 60-62 work out? Is it pretty much run like it would be on the 73-87 crossmember.
Thanks in advance
1930 Olds 5 Window Coupe
1960 Chevy 1/2 Short Stepside on 1965 Frame 350/350
1960 Chevy 1/2 3'' Chop Short Stepside "FOR SALE!!!"
1966 Toronado
1971 Cutlass
1972 442
1978 Chevy 1/2 Long Fleetside
2001 Dodge 2500
65stepside is offline   Reply With Quote
Old 07-24-2007, 08:43 AM   #2
Jonboy
Slots go on anything!
Re: 73-87 Crossmember Swap ????s
There aren't any 73-87 6 lug 2wd front ends. They all had 5 lug. I think CPP has some 6 lug rotors, though.
I think the power steering would be the same. There are a couple links on here about converting to the 73-up box. Tony has even had some spacers made. I would guess that you would use all of the 73-up steering linkage, and mount the box and idler arm to your existing frame.
Old 07-24-2007, 11:12 AM   #3
slepysal
slepysal's Avatar
For my 60 I am going to go with spindles. Now for the power steering I am using a Classic Performance Products (CPP) pn 6062psk kit it is made for the 60-62 frames wich are diffrent then the 63-66 frames. Good luck and keep us posted.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 08-05-2007, 10:15 AM   #4
65stepside
65stepside's Avatar
Alrighty, this may be a dumb question, but if i were to get a front crossmember out of a 4x4 73-87, all i would have to do to have a lower stance would be switching the spring and shock setup right? Again forgive my ignorance here. thx for your help.
1966 Toronado
1971 Cutlass
1972 442
2001 Dodge 2500
Old 08-05-2007, 11:27 AM   #5
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Well the 4X4's are a leaf spring front end...don't think there are spring pockets there.
John
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 08-05-2007, 09:06 PM   #6
PrerunnerRob
PrerunnerRob's Avatar
4x4s are solid axle up front, leaf springs.
PrerunnerRob is offline   Reply With Quote
