04-25-2002, 10:05 PM | #1 |
Hood lock for our trucks
What have you guys used or invented?
--------- 72 SWB K10 San Diego CA |
04-25-2002, 10:10 PM | #2 |
i want to know too, it looks like it wouldnt be that hard to make one from 73 and up work but i would like to know if anyone has dont it
Brandon, SD 69 GMC 1/2 ton 2wd wide long bed with wood 3 on the tree 350 engine 4 bolt main rv cam AIM = Alphray04 |
04-25-2002, 10:14 PM | #3 |
its all about the +6 inches
Kinda butch, but I have used a chain to lock it. Did that when i had to park The longhorn for a year whiile I was in korea.
------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio |
04-25-2002, 10:17 PM | #4 |
I bought a 68 from a guy and he welded a nut to the driver side of the hood latch and when you shut the hood he had a bolt that would run through handle on the hood through the support a to the nut on the other side. He cut a boxed end 5/8 wrench in half and tightened the bolt down. Works great and you can get regular wrench or socket on otherwise.
------------------ 1972 short fleet and soon interchangable short stepside beds 2wd with 68 front clip 350/700r4/3.73s 15x8 Truck rallys with 235/275 60s Orange and Black soon to be all Orange
1972 short fleet and soon interchangable short stepside beds 2wd with 68 front clip 350/700r4/3.73s 15x8 Truck rallys with 235/275 60s Orange and Black soon to be all Orange |
04-26-2002, 12:47 AM | #5 |
I am sure I have seen somthing sold at a parts store.. not sure what, who, or where.
------------------ Nick Rodenberg Wellington, MO http://nickrod.port5.com You can click on "My 72 Chevy Truck" I have a 72 Cheyenne 10 with a V8 350 and a TH-350 auto-tranny. Ochre/White/Ochre Runs well... working on body. Plan to get painted weekend before memorial day weekend. Planned to be done March 7 when I turned 16. Didn't happen. Chose to do better job and be behind schedule instead of 1/2 doing it and it looking like junk.
Nick Rodenberg 72 Cheyenne 10 V8 350/TH350 white/ochre/white/ochre, ochre/saddle interior Retired and in the dry... still runs. I now drive Red '01 Ford Focus... better MPG!!! |
04-26-2002, 01:00 AM | #6 |
Psycho-billy Member
I believe that someone said that JC Whitney had a hood lock. Not sure if it works on these trucks or not.
here it is... http://www.jcwhitney.com/item.jhtml?ITEMID=313&BQ=jcw2 [This message has been edited by 1972c10_ohio (edited April 26, 2002).]
'72 C-10 350 w/Lunati Voodoo cam (207*/213*, .437/.454), Performer intake, 625 Road Demon Jr. and Hooker headers. Support your community, support yourself. Buy local, buy American (or Canadian). |
04-26-2002, 07:36 AM | #7 |
December 21, 2012
Got a hood lock kit from NAPA. Consisted of a short chain with a type of wedge on the end that you pushed in a locking clip. Mounted the chain piece into a existing hole near hood latch then mounted locking clip on face of rad. support. Comes with a couple of keys to lock and unlock it.
"!Ama Sua, Ama Kjella, Ama Lllulla!" |
04-26-2002, 11:04 AM | #8 |
I took a piece of welding rod and drilled the hood latch where all of the latch handle is closest to the housing. then I slid the welding rod into the hole. I ran it over to the drivers side of the grille and let it sit under the edge out of sight. used some little pieces of strap on the back of the grille to hold the rod and put a screen door spring on it. worked great. kept several people out a year or so ago when I was still in high school. I'd take a pic but it's all disassembled at the moment.
Nathan ------------------ 1969 C-10 292 I-6 4 spd in the middle of a restoration. going to get a 327 and 3.07 gears but keeping all of the original parts so I can put it back to original later on down the road. 55 chevy 4 door 150 47 Willys CJ-2A
69 C-10, 340HP 327 55 chevy 4 door 150 47 Willys CJ-2A 05 Harley Night Train 06 1200 Sportster (Wife's bike) 70 Honda CL350 OIF2 & OIF7 Veteran Nathan & Tiffany |
04-26-2002, 11:59 AM | #9 |
faster, faster, faster
my neighbor put one on his 83 C30 van. He used an old cabinet hinge and a choke wire. He mounted the hinge right behind the hole on the radiator support. He made a small angled grove in the back of the latch hook. When the hood was down, the hinge would sit in the groove not allowing the hood to come up unless you pulled on the choke cable and pulled the hinge up. I would never do that to one of our trucks, I just thought is was clever.
I'm going to Law School, wanna debate? It's good practice. |
04-26-2002, 02:54 PM | #10 |
Here's my riggin'. I drilled a hole through the aluminum and through the latch handle. I flared a piece of stainless tubing and put it down through the holes, but under the hood latch assy, so you can't push it up. I marked where to drill the lock hole then took the tubing out and drilled it. The lock is a Master w/ black plastic shell, and I painted the brass bottom to semi-gloss black so it's less noticeable.
------------------ '69 Chevy Custom/10 SB '74 GMC Suburban 4x4 '66 Mustang Sprint '77 Sportster
'69 Chev Cust/10 swb, 350/700R4, 5"/6" '70 Chev C10 swb, 67 front, 454/700r4, 4"/5" '73 Chev stepper, 350/3 spd '84 Chev K20 350/4 spd '91 GMC 1500 Suburban 4x4, 350/700R4 |
04-26-2002, 02:59 PM | #11 |
I'm sorry I made the pic so big. That's the first time I posted a pic w/ this camera and program. I'm really computer dumb.
04-30-2002, 09:32 AM | #12 |
------------------ 72 Chevy Blazer 69 GMC Longhorn 37 Chevy Coupe pics at http://home.fuse.net/pierce Cincinnati, OH
69 GMC 1 Ton Longhorn 37 Chevy Coupe |
04-30-2002, 09:58 AM | #13 |
How can I follow that last post.
J C Whitny sells on and most Jeep catalogs sell the same one. They should work good on aur trucks. They used to be called chapmen locks. You use a round key under the dash to unlock. Just push in to lock. It uses a steel reinforced cable that goes through the fire wall and will also kill starter. I had one years ago worked very nice.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
04-30-2002, 10:06 AM | #14 |
OH jezuz Pierce where did you get that one,i found her on uglypeople.com
tonsa fun a mamba jamba-a country girl from alabalma(where in the hell did i hear that)i think its in a song [This message has been edited by Desert Rat (edited April 30, 2002).] |
