autometer fuel guage
I am having trouble understanding how to wire my new autometer fuel guage. I understand the power and the ground, then it says run a wire straight to the fuel sender? Is this the brown wire that is pluged into the fuse box? Also how do you test the sender wire? Do I set my multi meter to ohms then touch a ground and touch the other lead to the signal wire? And I should get a reading between 0-90?
Thanks for any help
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
Re: autometer fuel guage
You've got the right idea! But I just ran a completely new wire from gauge to sender.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
I may just do that it also says make sure sender is grounded is it grounded to the tank by contact then tank to body by contact? So All I have to run is wire from tank to guage from the same post the wire is now on sender?
Not sure if that made any sense.
Oh man
Real fun, I put gauges on my 62,there was a wire to ground the sender to the cab. On my 70 there is a metal tab that looks like a retainer for the in cab tank. I got the gauge to work but not accurately.
