Old 07-24-2007, 04:44 PM   #1
71tahoe
71tahoe's Avatar
Rear brakes gone on '71.
My son called me last night to let me know the brakes were acting funny and had previously told me they weren't working very well (long stopping distance). I told him it is an old, heavy truck and he should drive accordingly. Last night he found the rear reservoir "bone dry". He was also in a sharing mood a few days ago and told me about locking up the brakes when he almost ran a red light. That could have blown out just about anything in the system but I don't remember seeing any new leaks on the driveway.
I only have Saturday to work on it.
I plan to:
1. Inspect the rear brake hose.
2. Inspect each wheel cylinder.
3. Inspect the MC and add fluid/bleed.
I know I could have multiple problems. Anything else to look out for? I'd really like to get it done Saturday.
71tahoe is offline   Reply With Quote
Old 07-24-2007, 06:51 PM   #2
lukecp
Formerly yellow72custom
lukecp's Avatar
Re: Rear brakes gone on '71.
Easiest thing to do would be to put some fluid in the reservoir, have your son press the pedal down, and look for leaks. I helped a friend with the same thing on a Ford Ranger a few weeks ago, and we found the problem really easy when we heard it literally spraying fluid from a rusted hole in the rear brake line. The truck had sat for a few days and there weren't any puddles or drips underneath it until we filled the reservoir and pushed the pedal.
I'd be betting on the rear brake hose myself, but inspect all of the lines, including the hard lines. Best way would be to fill it up, press the pedal, and look for leaks.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 07-24-2007, 07:02 PM   #3
71tahoe
71tahoe's Avatar
I like me pumping the brakes while he crawls under the truck.
He doesn't like the truck being "grounded" until Saturday but he did agree to look today for anything obvious. The last rear brake hose I replaced had to be cut off by the frame. It was a real pain working in such a small space.
Old 07-24-2007, 07:03 PM   #4
Green Machine
Green Machine's Avatar
Master cylinders tend to leak out the back, and I assume your 71 has power disks. Might want to loosen the MC and move it away from the booster a little and see if there is fluid between them. Wheel cylinders are highly suspect, they usually leak slowly, check the brake lines, they usually would have a big leak easy to spot.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 07-24-2007, 07:05 PM   #5
nplocoman
never finish start another
nplocoman's Avatar
Could be the MC. If the wheels look dry, check under the floor mat near the steering column where the MC push rod goes through the dash. The fluid could be coming from the rear of the MC into the cab.
nplocoman is offline   Reply With Quote
Old 07-24-2007, 07:26 PM   #6
71tahoe
71tahoe's Avatar
Thanks. I've had the truck over 17 years and never replaced any hydraulic parts. It's probably time for it to go. Plus my 17 y.o. is driving it. He's got to go fast before he has to slow down. It's only fitting we replaced the clutch (or the 25+ pieces that once resembled a clutch)about 3 weeks ago.
